Trying not to restate what anyone else has stated, but I think the right side advertisements should be a little narrower than the left side ads. I'm running 1024x768 and I will say that if I were to cut out the ads and put them beside eachother and then put the article next to it, I think the ad's would be taking about 50% or so of space. (Although I realize you need ads and various funding to stay alive
Edit: I see the smaller ads on the left side now as well. I think maybe swapping the right side ads in place of the left side ads would look nicer imho. But, if the frameset calls for both sides to use the wide ads, shorten the width of at least the right side.
My one little thing, also, is the live search. I've also experienced the tab that pokes your bar and says "I'm hiding your DWORDS".
Maybe if there was an option to turn live search on when you logged in, that may be nicer of both worlds as it would:
A: Make people that don't like the live search happier
B: Still make search engine operate even though real time is disabled (although I don't know how that particular system works)
C: People that don't use the live search, and since it would be off by default (whether a guest at the site, or a members preference to turn live search off), would save bandwith. Maybe not much at the moment, but like quarters, it all adds up.
However, I haven't had much time to play around with anything else. I clicked around here and there, and I will agree, that the flash media ads are the cause of LOTS of time delays of the page loading. It should be set up so the load script sets up the frame layout and allocation of the objects FIRST before loading the actual contents that aren't text or .jpeg. This way, the frames for the flash are all ready to go, the main articles (what people want to read) are loaded all ready, because the frames are ready, when readers are in the middle of a paragraph, it won't jump lines because the site suddenly told Joe Smith's computer to load another banner frame, and everyone wins!
Also, because of the added interactive live search, and the increased ad flash content, I predict this will slow down older systems considerably. The live search won't do it as much as the ads will, unless the live search is using Java and taking up some good chunk of the Internet Browsers process block.
