Help needed. No sound (Pioneer VSX 520 & Samsung Q6FN)
N
nitse
Ratings
2
#1
Hi guys,
I am trying to connect my amp with my Tv using HDMI and there is no sound. I have a Pioneer VSX 520 and a Samsung Q6FN. You can listen to the noise when selecting tuner(no antenna) so I guess the speakers are correctly connected.
I connected the HDMI to ARC HDMI out of the tv with the TV input of the amp. I change the settings to the tv sto the sound is transimitted through HDMI instead of tv speakers.
I reset the amp to factory settings.
The link to amp's manual is: https://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-520_OperatingInstructions0302.pdf
HDMI keeps flashing
Any advice please?
Ratings
5,045 18 47
#2
Is your avr capable of ARC at all? Don't see any reference to ARC or audio return channel in your avr's manual. Just use an optical connection, same audio....
N
nitse
Ratings
2
#3
Thanks for the reply ! Yes probably you are right. I guess the only way to go is an optical fiber.
Any recommendation?
