Yes ratso I am crossing over at 160Hz, but perhaps thats not the best term to describe it because what Im actually doing is setting the bass to "both" in the unit with "large" for fronts, so it sends everything to the floor standers & on top of that sends a 'copy' of everything upto 160Hz to the sub. Only then is the lack of mid bass compensated for.
Sometimes I set the LPF/HPF down to 120Hz in some songs.
CruiseMissile, I understand what youre trying to say, but I want to ensure you have actually "heard" a SR6004 with b&w 683/comparable good speaker? Or are you "assuming", just like everyone else including me like I did a month ago, expecting the Marantz to be flawless?
The reason for that frank question is because I went & heard some Yamaha 10xx the other day. When you max out bass on that, it shakes the floor.
How is it that +9db on eq in a Marantz does squat, & +8 on a yamaha shakes the room?
Why is it that the equal wattage rated Yamaha is 10db louder than the Marantz?
The answer is going to be "oh each brand is different, you know what you like"
or "Oh Yamaha boosts everything"
Heard an Onkyo NR609, didnt touch the eq just maxed the bass, it shook the floor.
I'll go hear the NADs, Rotel & Classe very soon, then I will know if its all premium brands or just Marantz.
Lets say I do like to distort the hell out of my mid-bass, if I want to do so, & the reciever goes to +9db on eq, why is it not doing what +9 should do ie shake the room?
Other brands do that, is Marantz the only "real" & "good" sound, I find that hard to believe.
Ultimately, do you agree the receiver is not performing?
Also, I have run Audyssey correctly, frankly you can't 'not' run it correctly, you dont do anything beside start it. I have a stock car stereo & refuse to having a sub in there so lets not assume Im your bass junky measuring SPLs out of a car boot.
To me, my receiver not being able to drive the 2 woofers in the 683 very much makes my receiver "bad", else I would go by 685s & attach a sub. If you buy 3 way floor standers, they need to perform, else you dont buy them.
Anyway, best to go check the other primos out & post my finding later.
