You can upset the Cheerios all you like, I'm a Honey Bunches of Oats kind of guy
I tried looking this up and couldn't find anything as simple as Waterfall Plots. Could you post a link or few on them.
I look forward to your approach. Especially, since you say, its results are better than linear corrections through EQ to get flat FR and time domain control of room response with EQ and bass trap/diffuser application.
Well then, I'll try to keep things '
sweet' for you....
But believe me, if I could
shorten these responses I would! (but it's all condensed info coming from a 500p book)
As for frequency vs amplitude with phase as opposed to waterfall, that is information I am sharing from Floyd Toole's 'Sound Reproduction'. Floyd goes in to it a bit in his CIRMMT video on youtube. But the compromise between frequency vs time is the issue, and can give misleading information that would be wrongly used to input DSP corrections with.
Back to your RT comment: "Voices and musical instruments have limited sound power output, so (concert) halls are kept as reflective as possible to keep loudness high, without interfering with 'intelligibility' of the music. It is a difficult compromise. Typical values for RT in performance venues are in the range of 1-2 seconds, optimized for the music most commonly performed... In sound reproduction, the essential hall reverberation is captured in the recording, so nothing additional is required. Typical RT for domestic listening rooms and recording control rooms are 0.2-0.4 seconds. The reverberation in classical recordings completely overpowers that of the listening room." Pg 281 'Sound Reproduction 3rd Edition'
Point being that RT is not often an issue in small rooms. Understanding the transition frequency is much more important to identifying and treating the naturally occurring room modes or standing waves resulting from the parallel surfaces of your home. As you pointed out, the energy from the first reflection doesn't just dissipate, it keeps bouncing, creating higher order modes that are higher in frequency than the originating modal frequency. That is why I don't recommend adding DSP filters without predicting and verifying room modes, first, due to the near guarantee of unknowingly creating new problems(which may simply, be inaudible). Knowing that the energy keeps going, means you can calculate and KNOW which mode is the issue, and based on it's relation to your LP and your speakers will give you the information needed to constructively or destructively drive those modes.
My 'approach' is outlined in Ch.13 of the second edition, and Ch.8 of the third edition of 'Sound Reproduction - The Acoustics and Psychoacoustics of Loudspeakers and Rooms.' And I'll clarify yet again, my approach has been nothing but information gathering to get started. Applying DSP to create your own idealized graph is a misnomer. It is a complex subject without many simple answers, but gaining a better understanding of the subject of Sound Reproduction enables you to make informed decisions. But you can't do that, without knowing your room's influence.
From Ch. 12 p345 "When one sees a
very smooth high-resolution steady-state room curve after equalization, there is a high possibility that something inappropriate has been done, and the sound quality may have been degraded."
When you consider the amount of time being spent measuring and tweaking DSP filters, it is amazing for me to see the resistance to the
fact that the physical dimensions WILL correspond to the acoustic measurements. But clearly, my saying that is insufficient for those who haven't read the book. So I will do my best to upload my step by step correlation of predicted modes(and my room has a bunch!) to the acoustic measurements. I have to start a new photo host because all my other threads are picture-less after Photobucket changed their terms.
