@killdozzer
I have no first hand knowledge about XTZ. Thanks for providing the manual.
It seems good, and is more than powerful enough. 110 watts per channel at 8 ohms is plenty for you. If you like the price and the looks, I see nothing wrong. What does this model cost new and how does that compare to $750?
I like that it has pre-amp out jacks as well as amp input jacks. That allows you maximum flexibility for the future. You can use this as a preamp with an external amp, as an amp with an external preamp, or you can install another external device (such as a parametric equalizer) between the XTZ preamp and amp. That's the proper way to build it.
The user switchable class A - AB business is novel. Many amps are built with class A/AB operation, where at low watt power it runs as class A and above a certain power level, it switches to class AB. I wonder if people really can hear a difference. If I had the XTZ, I would set it on Auto and forget about it.
If the manual says nothing about a cut-off frequency for the sub out jack, I would assume there is none.
You should be able to find some type of dongle at a low price that converts USB digital audio from a computer to digital coaxial (4 on the XTZ) or optical (1 on the XTZ). Maybe you can find a sound card for your laptop that does this.
Of course, I like that $90 Yamaha better
