Play something. Turn your volume up 6dB and down 6dB. Then you tell me.
He's talking about the point at which its spl capability varies from the general +/- 3dB frequency response range of the speaker, the f3 is 3dB down (-3dB), f6 is 6dB down (-6dB) etc. It gives you a picture of how your speaker rolls off response at the lower end. Another consideration with a speaker is at what spl is this all being determined at, and why many don't try to "blend" speakers/subs at the spl levels they need...and cross them perhaps even at 100-120 even if their speakers have a -3dB point in the 30-40Hz range....at what spl can they do that?
Thank you all for trying. However, I'm a literature/theory of cinema professor. The dB/Hz relation is still not fully clear to me (but I’m trying, honestly).
After all you said, it seems to me you could pose that exact same question Herb did on just about any subwoofer. I mean, if you can’t read needed info out of the manual, who can give you the answer. I can’t buy measuring equipment and go through 20 subs.
If you’re not happy with the spl at which your sub reproduces as low as 30Hz, couldn’t you just turn the volume up on your sub? (This is how little I know
) I still can’t believe that if you put 1w into your speakers that you’ll hear the rated amount of dB at 1 meter distance. In all honesty, I still don’t understand why people (even here) say that you don’t need a sub in a small room. If your monitor doesn’t ‘make noise’ under, let’s say, 50Hz, what does it matter how big your room is? If it’s not there, it’s not there. (And please don’t tell me it starts reproducing bellow 50Hz only because the room is small or I will start pulling my hair out)
What Herb might have done is simply say; no, that sub is not good enough. I have no other choice but to trust what you say any way.
I am trying to determine (by ear) whether I’d be significantly more satisfied if I pair these monitors with a sub. During this process I’m trying not to lose too much money. Swerd already said that I could try with an ‘AE’ sub I mentioned in one of my posts, but that one I can only get new, which means that it is pricy to begin with and I will lose much when I try to sell it if I need to.
The easiest way I can think of is to borrow a sub, but I don’t know anyone who owns one. So the ‘second easiest way’ is to buy second hand. I figured that if I get it for 230$, I could sell it on for at least 200$ and this will not set me back too much.
The main problem, as I see it, by what you often write here, is that no one can tell me I would be satisfied even with a top SVS model. I have to listen to it and see for myself. And this was my initial logic: if I really like something that can ‘barely’ go down to 30Hz, there’s no reason not to be happy with something that easily goes down to 30Hz or 28Hz (given that other specs and conditions don’t change much, for example; if I like a cheaper model of KEF sub, I can aim for a solid medium model of KEF sub).
P.S.: (for the curious) I also intend to crossover main speakers a bit higher so that they don’t even bother with anything lower than cca. 70Hz. I expect they’ll do their job even better.
