I will take you up on that soon. Thank you by the way you have 9.2 right?
afterlife2 Audioholic Warlord Sep 18, 2013 #521 I will take you up on that soon. Thank you by the way you have 9.2 right? Last edited: Sep 18, 2013
fuzz092888 Audioholic Warlord Sep 18, 2013 #522 afterlife2 said: I will take you up on that soon. Thank you by the way you have 9.2 right? Click to expand... 9.4 currently
STRONGBADF1 Audioholic Spartan Sep 19, 2013 #523 fuzz092888 said: 9.4 currently Click to expand... Obviously compensating for something...
fuzz092888 Audioholic Warlord Sep 19, 2013 #524 STRONGBADF1 said: Obviously compensating for something... Click to expand... If that wasn't obvious already I must not be trying hard enough
ImcLoud Audioholic Ninja Sep 22, 2013 #525 Fuzz does the heat from your components ever trick the thermostat , that looks like a plasma? I know they get warm, mounted a few feet away on a common normally causes issues... plus the heat rising from the components?
fuzz092888 Audioholic Warlord Sep 22, 2013 #526 ImcLoud said: Fuzz does the heat from your components ever trick the thermostat , that looks like a plasma? I know they get warm, mounted a few feet away on a common normally causes issues... plus the heat rising from the components? Click to expand... It does and it doesn't. The place is so small that with the heat from the components, TV, and projector that in the summer the A/C has to be on 24/7. In the winter it gets worse. The attic is insulated pretty well, but there's no floor insulation so there's usually about a 8-10 degree difference between the floor and the ceiling, with the entire place being heated by the components. With the open face of the entertainment center plus all those fans the air circulates pretty well away from the entertainment center and the thermostat. Oh yea, I should also mention that our boiler crapped out very early this past spring and was somewhat sketchy before that so we had been heating with space heaters anyways. Good times
ImcLoud Audioholic Ninja Sep 22, 2013 #527 Time for a boiler, space heaters are dangerous and costly to operate.... What do you have for fuel? Oil, natural, LP? and what kind of emitters? Baseboard, duct work, radiators?
fuzz092888 Audioholic Warlord Sep 22, 2013 #528 ImcLoud said: Time for a boiler, space heaters are dangerous and costly to operate.... What do you have for fuel? Oil, natural, LP? and what kind of emitters? Baseboard, duct work, radiators? Click to expand... The last one was oil, but I'm pretty sure my old man doesn't want to go that way again (we rent from him, well sort of). I'm not sure what he was looking to get, or if we'll have to just ride it out for another winter. Baseboard.
ImcLoud Audioholic Ninja Sep 22, 2013 #529 fuzz092888 said: The last one was oil, but I'm pretty sure my old man doesn't want to go that way again (we rent from him, well sort of). I'm not sure what he was looking to get, or if we'll have to just ride it out for another winter. Baseboard. Click to expand... Well if you ever need advice on the topic, feel free to ask... Natural gas Triangle tube prestige boiler with a taco hec2 circulator on each zone piped primary secondary using purge tees, would e a good start..
fuzz092888 Audioholic Warlord Sep 22, 2013 #530 ImcLoud said: Well if you ever need advice on the topic, feel free to ask... Natural gas Triangle tube prestige boiler with a taco hec2 circulator on each zone piped primary secondary using purge tees, would e a good start.. Click to expand... I'm sure I'll need your advice someday, but as my Dad's friend (who is a carpenter) said about where we're living "If I were you I'd just burn it down." So I don't think all that stuff is an option just yet
fuzz092888 Audioholic Warlord Sep 28, 2013 #531 Hooked the Phils and the Salk up to the main setup and just got Abbado conducts Mahler Symphonies 1-7 on Blu-ray. And it looks like I did well. According to Blu-ray.com it would seem the box set contains a redone 2nd and 4th audio mix, which improved upon the standalone versions. I can definitely see why TLS uses the opening of the 5th to demo his system. WOW. Last edited: Sep 28, 2013
Adam Audioholic Jedi Sep 28, 2013 #533 afterlife2 said: I'm really pissed at you now. Click to expand... Me, too! After all, who blocks part of the screen with a sign?!
fuzz092888 Audioholic Warlord Sep 28, 2013 #535 afterlife2 said: I'm really pissed at you now. Click to expand... Hehe, the quality if the BD's is simply awesome and even though the surrounds don't match the front soundstage, to my ears, it isn't holding anything back. I've got the Phil's running full range and the center/surrounds crossed over at 80hz. The sound is rich and full, the soundstage tall and wide, and the imaging precise. The only thing that takes some getting used to is the camera angles changing while the audio stays anchored at the mics. It can make the video and audio seem almost out of sync, at least to me, until you get your head wrapped around it.
macddmac Audioholic General Sep 28, 2013 #536 fuzz092888 said: Hooked the Phils and the Salk up to the main setup and just got Abbado conducts Mahler Symphonies 1-7 on Blu-ray. And it looks like I did well. According to Blu-ray.com it would seem the box set contains a redone 2nd and 4th audio mix, which improved upon the standalone versions. I can definitely see why TLS uses the opening of the 5th to demo his system. WOW. Click to expand... 75.00 for the Mahler blu ray? Ouch! Worth it ?
fuzz092888 Audioholic Warlord Sep 28, 2013 #537 macddmac said: 75.00 for the Mahler blu ray? Ouch! Worth it ? Click to expand... Well to be fair, if you don't buy the box set I believe you have to buy each symphony on a separate BD which would come to $140-175 and I believe I paid Amazon $68/69, not that any of it is cheap. IMHO, if you enjoy classical music, especially really really well recorded and performed classical music, the price is a pittance for what you get, especially since the box set has all the best audio mixes from the performance (apparently there were a couple of them that had lesser quality or slightly compressed dynamic range if you bought the individual BD's). It won't be for everyone and a person's own equipment may also end being a limiting factor (not that I expect that to be a problem around here) so I'll throw my full recommendation of the box set in alongside TLSguy's for any classical music lovers. I've watched Symphonies 1 and 5 so far and I doubt 2, 3, 4, 6, and 7 will disappoint.
fuzz092888 Audioholic Warlord Oct 5, 2013 #538 Template time! What a time to find out my router jig can't cut a circle with under an inch radius.
macddmac Audioholic General Oct 5, 2013 #539 Drill press with hole saw or a high quality bit for that size.. Round over is a different story though but I'm thinking about it cheers, Mac Last edited: Oct 5, 2013
fuzz092888 Audioholic Warlord Oct 5, 2013 #540 macddmac said: Drill press? Click to expand... Ain't got one, so I ended up buying the Dewalt Hole saw kit, which should keep me pretty square (I hope). I guess we'll see how steady my hands are. [video=youtube_share;Mzcgyk62cHU]http://youtu.be/Mzcgyk62cHU[/video]
