Well I don't need it.
FR of a main speaker at 2 meters.
FR at MLP
So there is a slight shelving of the HF as there should be at the listening position. The room has a slight null at 80 Hz, but not serious. The sub outputs come in at 40 Hz. So this is set as you can see that at 2 meters they are set a little low and there is some room gain below 30 Hz. By measurement and listening this sounds to be optimal. The bass sounds very well balanced. So yes,, it needs leaving alone and forgetting to enjoy the music, which is the object of it all.
