Bi-Amping and Power Filtering Experiences
I experienced an audible hum and the L and R channels were reversed when I biamped my 3805 (I was first to post these issues a while back). Correct me if I'm wrong Gene, but if you biamping noise issues were caused by some kind of ground fault, would this not affect performance regardless of biamping? Although excited by the idea of 240 watts per main channel, I felt the elevated noise floor outweighed any performance benefits.
However, this is not to dismiss the importance of AC. I though this was a snake oil pandora's box, but as it turns out, there's something to it. I previously posted about my Sony KV34HS510 HDTV having green discolourations when on the same electrical circuit as the 3805, which is exactly what it was (
someone please tell me how or why?)
. When I used an extension cord to plug the 3805 into a different circuit from the TV, the discolourations dissappeared. I tried a few surge suppressor/power filters but none worked (bear in mind I tried a limited number and wasn't prepared to spend more than what the 3805 was worth, which is surprisingly easy to do!).
The product that finally did the trick was a Tripp Lite Isolation Transformer. It improved the picture so much that my wife turned on the TV and said "Wow! What did you do to the TV?" You'll be astounded by the heft of these things! As the name suggests, they isolate your component from the circuit and includes surge suppression and AC filtering. The models are rated by power output in watts (IS 1000 is 1000 watts), so match up the power required with the model and away you go.
However, they don't stock these in your local audio shop so you may have to order direct or have a store special order as I did (which was cheaper than ordering direct as I avoided shipping costs). This is the ONLY product that worked and won't break the bank (from $110 CDN). I can't wait to get a larger one for my audio components, I'll have my own little power station running my A/V rack!
