Enter to Win: HDMI Cable from Impact Acoustics!
Status
Not open for further replies.
jwenthold99
jwenthold99
1) Are you currently using HDMI?
Yes
2) What devices you have use HDMI? Do they work well together?
SA Time Warner HD cable box to Sony 55a2000 SXRD RPTV
Works well
3) If you are not currently using it, are you planning to upgrade? Why or why not?
Would like to upgrade my Yamaha Receiver to support HDMI switching
4) What do you think is the most exciting feature of HDMI 1.3?
Support of Dolby Digital HD, and other new surround sound formats
K
kleinwl
No.
None. N/A
Yes. When I buy new equipment... because I believe it make the cable cutter a little nicer and is a better transport (ie. free of analog/digital conversion noise).
Deep Blacks. However, I doubt if this will actually be implemented. So the higher headroom (bandwidth capability) is much more likely to be actually useful.
brucewoodington
Yes
Denon 4806, Dishnetwork 622, Sony HDR-SR1 camcorder, Sony KDS60A2000 tv. No problems at all.
NA
Dolby HD
mikeyj92
mikeyj92
Yes. Bluejeans Cable
Cable box & Oppo upconverting DVD player. Not one issue.
Am using it.
Not sure. I'm not totally up to spec on 1.3. I'm looking at receivers at the moment and am resigned to not worry about 1.3 at the moment for anything. I just want something that works and does audio/video well in one cable.
V
Vanhoecke
Entry
Contest Questions:
Yes
Cox HD cable box to 42" Sony
Putting in Home Theater, will use HDMI for projector, sourced from HD DVR, HD DVD and Blue Ray players.
New sound formats, such as HD and Lossless audio.:rolleyes:
BMXTRIX
BMXTRIX
Nope!
I have a Sony 400 Disc DVD changer, PS3, and two HD cable DVR boxes... They all work great - cause I'm using component and matrix switching.
I would like to upgrade to HDMI, but I've gotta have matrix switching with it so I can do HDMI distribution throughout my home.
Advanced audio support and deep color. Hopefully it'll help get rid of false contouring with digital displays... Wouldn't bet on it though.
Jack Hammer
Jack Hammer
Q!
1) Yes.
2) My tv and dvd player have hdmi 1.1. If you watch tv while listening to a cd in the dvd player (sound via coax into avr), sometimes every few seconds the sound will cut out. Other than that they work fine.
3) n/a.
4) Wider bandwidth for future use = potential for much better SQ.
Thanks
Jack
N
nhpm510
yes
TV-dvd and cox hdtv - monoprice swicher box, yes work well without spending a fortune.
3) If you are not currently using it, are you planning to upgrade? Why or why not? n/a
Newer sound formats.
chungkyu82
Yes
DVD player and PC to my HDTV
N/A
Sounds are included!!
Brion8
Yes.
42" Plasma, Oppo DVD, Directv HD20 DVR. Yes, they all work great together.
n/a
Haven't read up on it yet.
DMD123
Contest Questions:
Yes
Sony XBR1 SXRD television and Marantz DV7600 DVD player. They work fine together.
3) If you are not currently using it, are you planning to upgrade? Why or why not? N/A
New sound formats.
Robo
Yes
PS3 to Plasma works very well.
N/A
Newer sound formats are always a plus, hopefully it will be a noticeable improvement.
ctwed
Hdmi
Not yet.
I have a HDMI capable DVR. I am not yet using the capability.
I am planning to upgrade all non-HDMI equipment (AV Receiver, TV/Monitor, CD/DVD Transport, cable/satelite box) as soon as the 1.3 spec. becomes generally available and is shown to be stable.
Improved data transmission quality, ease of use, as close to future proof as we are likely to see in the near future, ability to get full benefit of enhanced technologies.
Josuah
1) I am using DVI, but no HDMI.
2) None of the devices I own have HDMI inputs or outputs.
3) I have no immediate upgrade plans since I don't plan to purchase any of the new media formats until I can make electronic backups/copies. i.e. when the DRM is cracked for good.
4) Audio transport capabilities. I really want to take advantage of lossless audio in movies.
BabelFish
Not yet.
N/A
As soon as I build my HT I will be!! I can't wait!
The support of all of the new formats! :)
Bryce_H
Bryce_H
Yes
An Epson 550 front projector and a DishNetwork HD DVR - work fine together, however will be adding an Oppo DVD player soon so will need a switcher as my Denon 3805 does do HDMI switching
Handle the new formats - maybe actually going to a single cable connection
WooHoo
WooHoo
Pick me, Pick me!
1) Yup. I am using HDMI.
2) Yammi 2700, Sammi Blu Ray Sammi 56" DLP and D* HD STB. Everything works together except for the D* box but not to worry because D* has been a month away from a fix for about 6 months!
3) NA
4) Not sure 1.3 is exciting at all. Too much confusion for me. Custom installers seem to be more excited than anyone else.
G
GACrabill
No
None
No, don't have any HDMI capable equipment.
Don't know.
V
Vart
Yes
Only have one device - HD cable box
n/a
New sound formats.
K
kono144
Contest Questions:
1) Are you currently using HDMI? Yes
2) What devices you have use HDMI? Do they work well together? yes from DVD to TV
4) What do you think is the most exciting feature of HDMI 1.3? added number of colors
Status
