Energy Take speakers vs. other satellite/small bookshelf speakers-what do you think?
arielshiran
I have an opportunity to buy a set of Energy's new Take speakers and I consider to buy the following setup:
1 Take LCR speaker as a center speaker
4 Take SAT speakers as front+surround speakers
1 S10.3 subwoofer
This set will work with a receiver like Denon 2105/Onkyo 602/Marantz 5500/Harman Kardon 235/335.
I wanted to know how this set will perform (in both music and movies) compared to:
1) 4 M&K K5s, 1 M&K K7 and a KX-10 subwoofer.
2) Mordaunt Short Genie.
3) 5 Anthony Gallo A'divas and a TR-2 subwoofer.
4) 4 Monitor Audio Radius 90 speakers, 1 Monitor Audio 180 and a 360 subwoofer.
I wonder if the Energy is a good performer as it is quite a new set and I found no reviews on it.
Please help me and tell me what you think if you have heard this set.
Energy was known for a great 5.1 compact packages and a great value for money (Encore, older Take series, Act6).
Thanks a lot,
Ariel.
mfabien
I use Energy Take 2.2 as surround speakers and am quite happy with them and the rest of my Energy speakers (XL-250 Fronts, XL-C100 Center).
arielshiran
Thanks but
I was talking about the new TAKE speakers which are intended to replace the Encore as the Act speakers are the successors of the old Take speakers...
Red
Ariel, I have the Energy TAKE series in a 6.1 set up using the LCRs as the center and Front/Right and Left and the SATs for the Left/Right and Back surrounds.
I don't have the Energy sub, instead using a Velodyne DLS 3750, also a 10".
For my ears this is a very good value. If you have just a couple of extra $$$ I suggest you consider the LCRs for the fronts instead of the SATs. they both require stands so the footprint will be the same and the LCRs provide a fuller sound with (2) 3 1/2 woofers vs the (1) on the SAT.
Also, for bass management I found it best to set the sub crossover at 100db as the rolloff on the LCRs is 75 and the SAT is at 80.
All in all, with a good sub, they produce a very clean and rich environment,
I have not heard the others you listed, but if you decide on the Energy's I think you will be happy. good luck and enjoy the hunt
arielshiran
Thanks but
I will have to wall-mount all of the speakers and therefore from aesthehtic reasons I think that wall mounting LCRs will be less aesthetic than two SATs (I don't have a plasma/lcd screen and I intend to wall-mount the speakers in corners of the room).
What other options did you look at before buying and how much did you pay for the speakers you bought?
arielshiran
Can anyone else help with his opinion/experience?
Every comment is welcome :)
