Emotiva XS15 a review
  • Thread starter Thread starter Danzilla31
Danzilla31
7,179
0
113
52
It has begun!!!!!
I'll get it in the house get it upstairs and then run errands be back about 2 or 3 so we can unbox this bad boy!!!!
I will say this Emotiva is not fuggin around with shipping Freight R&L was the carrier same shipping company that delivers my RBH gear great company.
First time in I don't know how many orders a sub or speaker box has not taken any damage and this came in FAST.
I just ordered it 3 days ago!
Shipping 10 out of 10 Emotiva
Ohhhh yeeeaaah I just got 135 lbbox up 3 flights of stairs all by myself
I still got it baby! :D
I'm running an errand and I'll be back by 3 to get crackin on this
  • Funny
Reactions: Eppie
Nice. About the same weight as my Epik Empire was and I had to get it up 3 flights of stairs.
  • Like
Reactions: Danzilla31
I hope you used a dolly. Carrying something that heavy and awkward up stairs would take a terrible toll on your back.
I was careful. My job is very physically demanding so I need to be careful can't afford to get hurt and not work. So I made sure to be careful. Appreciate you looking out tho.
I just got back from errands I'm gonna take a quick break then we will start diving in
  • Friendly
Reactions: panteragstk
Oh, he’s single, all right.
…and clearly due another round of therapy for his Port fetish.
:D
(Nope, ‘Zilla my friend… still hasn’t gotten old! :p )
It's a slot port I'm learning. My therapist would be proud! ;)
Are you single? If not your wife needs to be nominated for some kind of award.
I'm TERMINALLY SINGLE. You think any good woman in her right mind would tolerate this sh$t?
But that's okay I like being single.
Even if I do cry myself to sleep at night ;)
  • Like
Specs
Output Specifications
Frequency Response: 20 Hz - 200 Hz +/- 3 dB (with LF Boost control set to 0 dB). LF Boost Control can apply up to -3 dB cut, or +9 dB boost, at 30 Hz.
Driver Complement
Heavy duty long throw 15” forward-firing powered driver.
Non-pressed paper cone reinforced with aramid fibers.
Tough SBR rubber surround.
Non-magnetic cast aluminum frame.
3” copper voice coil and vented pole piece.
Amplification
Amplifier: Audiophile quality class A/B amplifier with oversized toroidal transformer.
Power: 600 watts RMS.
Inputs
Both balanced XLR and dual unbalanced RCA inputs.
Electronics
All operating controls and status indicators are located on the rear panel
Crossover with high quality 12 dB/octave analog low pass filters.
Continuously variable Level control.
Variable Crossover Frequency control: 60 Hz to 150 Hz.
Variable Phase control: 0 to -180 degrees.
Variable Low Frequency Boost control (LF Boost control can apply up to -3 dB cut, or +9 dB boost, at 30 Hz).
A truly transparent advanced multi-stage low-distortion limiter.
Auto-on circuit powers the subwoofer on when an audio signal is detected.
Cabinet
Heavy-duty furniture grade acoustically inert HDF cabinet with integral rubber feet.
A tough yet attractive exterior, finished with multiple coats of satin finish black lacquer on the front, and tough attractive textured vinyl on the rear and sides.
A removable sculpted fabric grill. (The cabinet is fully finished on all sides and looks great with or without the grill.)
Low noise, rear-firing, slot-loaded port.
Environmental and Mechanical
AC Power: User selectable 115 VAC or 230 VAC 50/60 Hz operation.
Dimensions: 23-5/8 inches high x 19-3/4 inches wide x 24-1/2 inches deep. (Permanently attached non-slip rubber feet included - but be sure to leave clearance for rear heat sinks and cables.)
Weight: 136 lbs. (boxed).
Weight: 114 lbs unboxed
I have to run up to work for an hour I'll be back to finish this up. Already unboxed and pics are coming!!!!!
  • Like
Reactions: adk highlander
Packing
This is one of the best packaged speakers or subs I've ever experienced. Right up their with RBH and SVS and Rythmik
High quality inches thick foam top and bottom doubled boxed doubled wrapped in cloth. Just a superb job with packing
10 out of 10 Emotiva great job
They also had holes cut out so 2 people can have handholds to make easier to lift and carry superb very nice touch 20230914_162852.jpg20230914_162510.jpg20230914_163216.jpg
Appearance. This is a very nice looking sub one of the nicer ones I've seen in awhile.
They have this vinyl that's textured in a way that it looks and feels like leather. And it's a nice nice touch. It looks and feels niiiiiice
The front has this smooth satin metal apoearanc like the front of a Martin Logan speaker. It's angled and it really makes this sub stand out. It looks mean and ready to go but sexy with the sharp lines and offset angles
The amp looks clean it's laid out very nice with RCA inputs underneath XLR inputs nice touch
Underneath that is an auto on or on switch
Gain or volume knob
LF boost knob
Crossover knob
Phase knob
This is an class AB amp and it has massive heatsinks in the back they look sharp though. Very clean good looking well laid out amp
8 to 9 out of 10 on appearance
I'm getting ready to fire her up
Tonight will be subjective only
I work a 16 hour shift tomorrow so Saturday I'll post in room measurements
I was curious about the XLR Emotiva is known on their regular amps to have the pins 2 and 3 reversed from normal gear but I contacted Emotiva support and they let me know the XLR pins on these sub amps are to the standard like what we are used to
The driver is big man it measure 14 inches from rubber surround to rubber surround but when you measure the outside edge like most do it's over 15 inches more like 16
  • Informative
Reactions: shadyJ
Okay subjective impressions
First I had a hell of a scare turn everything on. Send a test tone through so I can level match. There's a staticky sound and then a loud POP!
I turn everything off and think F&-+ck MY LIFE
It was on the auto setting so I turn the switch to on and decide let's find out if the amp or woofer is blown.
ANNNNND everything is a ok sub is fine
I've heard that sometimes amps especially when first running can have a static discharge so maybe that what it was
Moving on.
It feels so good to hear CLEEEAAN LINEAR BASS again in this room
This sub plays clean it's fast clear dynamic and it can get loud. But it does all when it's exactly supposed to. And nothing more. Like all really great subs it stops and starts right on a dime.
Every note clear and articulate every bass instrument sounds exactly the way it's supposed to
It's way too much sub for this room it's at -10 on the receivers trim and the dial is at 11 on the sub volume :D. And I don't care
All the headroom I need without even trying
It sounds exactly like my Rythmiks
It had that incredibly tight accurate bass with that incredible tactile response that Rythmiks are known for.
I fuggin love this sub
Can't wait to do measurements this Saturday
Man this sub is going NOWHERE I love it
It looks so good with the M&K's I've finally got the setup I want in this room so happy.
Now I have to get up for work at 6 :D:D:D:D
Dan you are in real danger of having perfect setups and not being able to buy new things! That's going to be a problem for you.
I know your RBH room is now maxed out I believe
Bedroom is getting there quickly
Both rooms are already there and Im done for now but like I mentioned in a previous thread I still plan on buying and trying new speakers at least twice a year. I'll flip them for a liveable loss. I plan on demoing them in the theater room. It has the proper space to let towers breath and the room is treated correctly so we can see how they measure in a properly treated room
In the bedroom I can try out and measure bookshelves. The new JBL studio 6 6-inch bookshelves are real high on my list for next year
I only live once and I want to experience as much audio as I can while my ears are young enough to allow it
And my friends on these forums well you can share that journey with me
Yes nothing wrong with just having fun with gear! That's part of the hobby for many and I enjoy when you do it so I can learn what's good and what isn't
  • Friendly
