Denon X3800 shuts down
On further consideration (I get smarter slowly, but do learn), I no longer expect the onkyo to actually solve the problem. Delivery on the onkyo is expected Friday (or perhaps sooner). so I'm going to wait for it to actually show up.
In the mean time its time to do taxes... Fun (not really).
Enjoy!
If the X3800H was shutting down right on the edge, such as, if you listen at lower volume by even just 1 to 2 clicks, then the RZ70 will solve the problem.
The suggested external amp route is only to give you more margin, that's all.
The RZ70 will give you about 1.5 to 2 dB at the most more spl at rated output vs the smaller/lighter Denon.
Is your R700 same as the Reserve R700:
If it is, it is practically closer to 4 ohm nominal than 8 ohm nominal, say 5.5 ohms lol..
and note the reviewer's comments:
Polk Reserve R700 Floorstanding Loudspeaker Review:
I measured the sensitivity at 88.9dB at 1 meter for 2.83v. That is very close to what Polk reports. That is pretty typical for loudspeakers in this class. Users will not need a monster amp for these speakers to get loud. However, they should be able to take a good deal of power if a beefy amp is available.
So, it really depends how hard you would push them, if not too hard (such as lower volume, sitting not too far etc.) then the RZ70 will be great for them without help from external amps, otherwise the protective circuitry might activate, worse case would be it might activate to limit voltage/current, without shutting down, so you might lose performance without knowing.. Some users of the lower models are not happy with that kind of protection, though they tended to be from owners of the lower models, the RZ70 is probably too new to have a lot of user feedback yet. You seem to have use case for probably more "power" than a lot of people, that's why I mentioned some of the things to watch for using the trial period.
Happy Joe
Happy Joe
Yes, I am using Polk reserve 700s... they are about the closest that I could find, locally, in a "new /current production" speakers at a semi reasonable price that sounds close to the old NHT 2.5i speakers; my favorites for the last 20 years or so...
I, typically, listen to music at levels that you can talk over in a normal voice (one of the first things that I look for in quality speakers).
Movies tend to get a bit louder (especially the special effects. Atmos seems to be especially good at shutting down the avr).
100 Watts RMS per channel, 0.01 or better THD is my historically minimum amplifier power level specification.... until these polks.
Enjoy!
Enjoy!
That's why I never like the term "power", ie "watts". Electromagnetic speakers are really voltage sensitive device, not power so if the R700 produces about 88 dB/2.83V/m, if you sit 4 m, you get only 76 dB assuming no room gain.
That's probably what you listen to a lot of times, but that means peaks could be at 96 dB or higher, fast approaching "reference" level!
Then consider Ohm's law, during impedance dips to 5 ohms, current will increase 1.6 times and that's what the AVR would be sensing, not "watts" whatsoever. At the higher, or highest current demand, the so called "watts" the amplifier has to supply is not that easy to estimate, it could be lower or higher than one thinks, the important thing is, the amplifier has to be able to meet the current demand while distortions remain lower enough to be audible.
Happy Joe
Happy Joe
For your reasons above i always take the Amp (power) specifications as a maximum that that the amp can supply without disrupting the distortion number too badly.
There is so much variation in the levels on recordings (for many reasons) That I don't even try to relate it to what I hear.
Specifications are only a rough guide, IMO.
When comparing speakers I bring my own copy of a recording; and where possible try to play the recording flat; even this, I realize is risky because of tricks that can be used to make audition rooms sound better than most folks can achieve at home.
... always take all published numbers with a large dose of of salt (especially chinese specifications since they, demonstrably, are not particularly truthful).
I ultimately don't place much trust in advertised numbers; I do try to go by test results from reviewers; where they give their methodology & are not terribly subjective/obviously biased...
Numbers can only take people so far because what individuals like/prefer is obviously subjective and can vary drastically between people.
Enjoy!
I do not run a lot of EQ; However the polk R700s seemed to need around 4 DB of boost to achieve parity in volume with the other speakers (I also have reduced the other speakers to levels that were near the polks however the resulting volume was so low that none of the speakers really gave good sound unless the volume was set quite high. (70+% or so.)
I have also tried splitting the difference (decreasing the levels on the other speakers while still giving the polks 2- 3 db of boost; still get shutdowns.
I figure the power supply on the 3800 just cannot handle the polk requirements, when the polks are boosted; resulting in random shutdowns (which do not happen with no boost on the polks).
Before getting more amps I expect to much more research, the emotiva, outlaw and crown options were a result of a quicky first pass look.
Enjoy!
Are you driving the speakers full range? Are you using Audyssey? At lower volumes the Dynamic EQ is a nice feature to provide a fuller sound. Most of the time my avrs suffice for power, but as I have spare amps I did hook some up in my biggest room (where I'm more likely to push volume too). Not sure why you need to lower levels of other speakers and boost the Polks, but that sounds a bit odd (altho preference isn't particularly reference otoh). How do you figure a percentage for volume with a dB/logarithmic scale?
The Onkyo's Dirac feature could be interesting, but I think Audyssey with the various app options is pretty flexible (multeq editor app, multeq-x, or even freeware like Audyssey One variants let alone buying a Dirac license).
Happy Joe
Happy Joe
Full range? probably not for music i have been listening at around 30%,
Audyssey? no, I haven't found it gives significant improvement over manual adjustment... Decided last night to give the polks a 2 db boost ; worked fine for music (no shutdowns)... would have gone for 3-4 but that seems to increase shut downs.
The lowering of the other speakers while giving the polks a slight boost was an experiment to see if it would reduce the power draw enough to achieve an overall better performance while avoiding shutdowns, it was a result of noting that shudown were reduced after disabling the height speakers. It might have helped slightly for effects movies no real effect for music.
% db with a logarithmic scale...I'm just going by the numbers from the on screen level display... It may not be correct but it seems consistent...
I agree; the Onkyo's Dirac feature could prove interesting.. at least, somewhat educational... Although most of the audyssey features are currently turned off.
The migration to the Onkyo is going to be a bit of an effort. I will need to remove the HTPC from below the Dennon then disconnect the cabling , move in the; somewhat weighty, as I understand it, Onkyo and reconnect everything.
Enjoy!
Enjoy!
There is no percentage involved in the volume control particularly. To move 3dB on your volume scale involves a doubling of power....there are two general volume displays, absolute and relative, but both are dB based (not percentage). You might have needed to do some more work with Audyssey....did you use the editor app at all?
Enjoy!
I don't understand why you are replacing one receiver with another. Receivers are a compromise however you paint it. You need a decent capable power amp to put this issue behind you. The optimal solution is an AVP and power amps. Decent power amps power speakers properly and without your type of issues.
Have you forgotten one important fact? Lots of people wants one box, not two or more, that's the main reason why AVRs was born and still reproducing lol..
Another reason is, many people likes your suggested optimal solution that is an AVP and power amps, but they also like the very fact that AVPs typically (plenty of exceptions obviously) don't go on deep discount sales as often as AVRs. There are many AVR models so their street prices tend to drop much more quickly and more than AVPs, so those people prefer to buy those cheap AVRs and use them as AVP but this is not the case for the OP, who seem to want AVR because of the "one box". That's just my take, only the OP knows the real reason.
Edit: Forgot to mention that AVRs that has a full set of pre outs also offer hybrid optiona, that is, pair it with a good quality 3 channel power for the LCR channels and use the build in AVR amps for the less demanding surround channel speakers (not always the case, but often are). In that case it is not a one box solution, but it could be much more budget friendlier than an AVP that requires external power amps for all channels.
The point is that he s making a change and likely to get the same result. He needs a power amp or different speakers. Those are the choices that will solve his problem.
I get that people want a one box solution, but these Atmos receivers packed with miserable power amps are insane.
I doubt people can even engineer Atmos properly in most spaces. What we really need a lots of 2 and three channel AVRs, that would make sense. Two really good channels beats a bunch of lousy ones any day. No wonder there are no takers for Denon Marantz. No one sane will touch it with any offer except for naming rights.
Happy Joe
Happy Joe
Since I long ago gave up making circuit boards and populating them (and vacuum tubes with point to point wiring are even farther in the stone age past) I am faced with getting the best compromise that the marketplace offers. I am one of the folks that wants a "one box" solution (having lived with multiple amps (as many as 6 for 2 channel stereo, ignoring the subwoofer and its amp & filter) and all of their various interconnection issues; I find a great desire for simplicity.
Since it looks like I have a power problem; I will try using a more powerful AVR (not sure if I will like the Onkyo; I like the published features of Dennon slightly better; but it will likely do for a trial.
As I have mentioned I am rebuilding ta set of NHT 2.5 I speakers (currently awaiting (titanium) tweeters and they likely need a crossover refresh due to age) these will provide an acceptable different speaker option if the Onkyo proves unacceptable. In the mean time I am close enough to acceptable sound to use the Polks, without equalization, to get by for the next few months. I find myself increasingly more dissatisfied with the Polk ring tweeters, I may replace them with domes, or inverted domes in the future.
I may, or may not, play with mono blocks as an experiment since they are inexpensive (Thank You, for bringing up the option)...
Thank you all for your time, hep and information; you have all been very helpful.
I will continue to monitor this forum.
Enjoy!
Verdinut
Verdinut
Enjoy!
You can't replace tweeters as you think. The tweeters that are in your Polk cabinets are a good match with the other drivers. An over the shelf tweeter will not work properly and the crossover would have to be modified to meet the Thiele/Small parameters of the replacement tweeter. No, speaker building and modifying is not an easy task. You need an adequate knowledge of speakers to do it.
Enjoy!
Meant to also mention by full range I mean speakers without any filter/crossover for a sub, not the volume range.
Happy Joe
Happy Joe
Yes; I listen to music flat; no equalization , normally (good speakers and fair acoustics can allow this). also without subs ('though I may try one, again this weekend)
Traced the intermittent shutdown issue to my sony 4k player (once again; after numerous failures; I find that s**y is still a four letter word...
Panasonic UB820K, on order, should be here today.
Crown amp (XLI 800) installed, using the front L&R pre-outs on the Denon; Does not hurt, nor help the sound, significantly (using my back up blue ray player); as far as I can tell; during a very short listening session last night.
Life is looking up...
THANK YOU! all for your time and suggestions...
Enjoy!
Eppie
Eppie
Enjoy!
Adding an external amp should not affect the sound in general. Amplifiers have very flat frequency responses so any tonal adjustments are left to the pre-amplifier stage. At least at moderate listening levels. Not until you drive the weaker amp into distortion or clipping should you hear a difference. You may notice an audible difference at high volumes as you gain additional headroom with higher power amps, so those amps are able to handle transients much better, while the weaker amp may hit its limits. Hope it solves your shut down issues.
That is not completely true. Changing speakers can and does change the FR in some cases. It all depends on the output resistance of the amp. This is a spec most people don't pay attention to, because amps are tested into resistive loads.
Peter Walker of Quad explained this to me many years ago. He explained that the amplifier designer has a responsibility to keep the amps output resistance as low as humanly possible. That is true of his designs. If the amps output resistance is on the higher side, it has a strong tendency for the FR to start to follow the impedance curve of the speaker. So changing an amp for one with a lower output impedance, can change the sound from the speaker. That is another reason why I would never use and AVR.
Happy Joe
Happy Joe
...Yes, I agree. as expected..
The amp was ordered to more closely match the speaker requirements as opposed to the 105 watt Denon output rating.
One reason for intermittent shutdown was speculated as insufficient power... it was a defective 4k player.
since I already had spent the $350, I decided to hook it up and try it out; without unexpected results...
Again; Thank You! all for the responses...
Enjoy!
Happy Joe
Happy Joe
Unfortunately, as I become evermore antique, I find that I am loosing the ability to hear fine differences in frequency response...
Enjoy!
little wing
little wing
I would be perfectly happy buying a 5 channel AVR with robust amps and two sub outs. But I don't think one exsist, maybe I'm wrong though.
Happy Joe
Happy Joe
I had an Onkyo Tx-RZ70 on order but apparently it fell into a black hole at a UPS site,... never to be heard from again... I figured that the (possibly class AB) Crown amp could give similar results (200 to 300 watts)(when combined with the denon bells and whistles, at a much reduced price... Adequate power gives reasonable sound in my experience.
Enjoy!
