How do you explain the AVR's slightly better
pre amp specs, even THD+N ? The prepro's SNR looked much better, but that obviously have to be compared with the Marantz power amps due to fact that the AVR's number is for input to speaker output? When you do, you will see that the AVR's SNR fits in between the power amp MM8077's RCA and XLR's 114.83/104.31 dBrA (note: so much for those who insist on XLR even on short runs
For the AVR, the THD was measured at the speaker outputs, yet the number was still a touch lower than that of the AV8802, measured at the pre out, that's amazing.
In regard to @M.Code's point about the 1 kHz vs full bandwidth output figures, on Gene's test bench, the little AVR-X3300W's dropped from 119/165 W to 105/154 W at 0.1% into 8/4 ohm.
That's a drop of only 13.3% 8 ohm, and even less into 4 ohm by only 7.1%. I know, that's just one example.
http://www.audioholics.com/av-receiver-reviews/denon-avr-x3300w-1/measurements
If Mr. M.Code has AP graphs that show the X7200WA drop 25% I would like to see it, but the Marantz power amps (e.g. MM8077) may have similar/comparable drops in output too.
Now, it's worth noting that my ex AVR-4308CI did the following on the S&V bench, 2 channel driven:
198.6/218.9 W into 8 ohm, at 0.1% THD+N
298.0 W/343.4 W into 4 ohm, at 1% THD+N
In that case, even with a 25% drop in output on a full bandwidth test, the numbers would still have met or exceeded the specifications.
https://www.soundandvision.com/content/denon-avr-4308ci-av-receiver-measurements#wEeQRQ23xtk5Ez8e.99
AVRs no doubt have to compromise but they do represent better values for a lot of people, and occasionally, some may even do better than some separates on bench tests done in the same lab.
Let's hope Gene will do his full reviews on both the X8500H and AV8805 soon.
