Denon AVR-X7200W won’t power on
  • Thread starter Thread starter Scooter2069
Scooter2069
4
0
1
49
My Denon AVR-X7200W won’t power on. No repair shop within states of me. I work on cars but never with electronics. Wanted to see if someone on here could help me diagnose and fix this.
That unit was last built 10 years ago. There will be no parts and a unit like that is not really repairable. It is a recycle job.?
It has a small LED above the power switch- is it red or is it not illuminated?
If the latter, make sure the power cord is fully inserted- I have seen several that worked their way out enough to prevent it working.
No light and cord is all the way in
No light meaning nothing is illuminated
@Scooter2069 , I see you just joined today and WELCOME! There are many people here, "In the Know."
In view of that clarification there are some steps you should take.
First make sure there is actually power at the receptacle it is plugged into. If OK, try a new power cable.
If power light still does not come on: -
Open the receiver and see if there are any replaceable fuses. If so remove each fuse and test for continuity with your multimeter. If you find any blown fuses replace them with ones of IDENTICAL current and characteristics. Make sure if it is a slow blow type you replace it with a slow blow type.
Usually fuses blow because of a serious malfunction in the device, but not always. If the fuse blows right away this is as far as you will be able to go.
At the moment Sound United, the current owners of Denon is in turmoil. I sent in a five year old unit that they were unable to repair, because of lack of parts. Then its slightly newer replacement failed at three months and has been in for repair under warranty for just a few days short of three months now, and I have heard nothing from them. So I bought their top of the line replacement model the Marantz AV 10. So far, so good.
Sound United who own a lot of brands, have an offer of purchase by Harmon, now a subsidiary of Samsung. Because Sound United own so many brands, and so does Samsung, this sale is under review by the Monopolies commission. Your guess is as good as mine what their ruling will be. They won't release their decision until the end of the year at the earliest. Currently the owners of Sound United are Masimo corporation, a medical equipment manufacturer based in California. They have made an absolute "Dogs Dinner" of Sound United under their ownership and it is shedding money like no tomorrow.
Fuse and cord are not the issue. What is best way to trace a faulty circuit/board
The answer is you can't. These units are unfixable except by a factory authorized service center.
The reasons are legion, But include: -
No service manuals or circuits are published. That pretty much stops you right there.
Surface mount components installed by robots using hot air soldering. So that makes repair only by board replacement.
Installation of proprietary boards requiring proprietary software, such as rebooting BIOS for instance. A lot of software manipulation goes into repairing these types of units as a rule.
Law requires that parts only be available for seven years, but if the production run, runs out, which it virtually always does, then that gives them an out.
So what I am telling you is that, your receiver is now unfixable junk, and has to go to the recycling center.
If you want gear that you could learn to fix, then you have to go vintage and way back.
This is why I keep and use as much really good vintage gear as I can. I can and do repair it, but it seldom needs it.
I have had a costly AVP fail at five years, that Marantz could not fix. That was a Marantz 7705. Its replacement the Marantz 7706 failed at three months and is in for warranty repair. I have heard nothing and if I don't hear from them before the labor day weekend, I will start enquiries.
So I bought a really costly Marantz AV 10. My needs can be met by way less than a handful of units. So I had no choice.
So this is the current state of the industry and if you think it is unacceptable, then I agree.
First call will be to a lawyer, or directly to the FTC?
A good class action lawyer should be able to find info about failure modes and rates WRT brands/models/region/warranty status and any (feeble) attempts to rectify the situation.
A large class action lawsuit may be like kicking someone when they're down, but they (Masimo) caused their own problems.
I'm afraid that the advice you were given is correct. I have repaired many vintage receivers but modern AVRs are too complex. Just to access the fuses can be a chore sometimes as they get buried under layers of circuit boards. At best, if the power supply board is accessible, you can test for voltage using a multimeter but even that is not that straight forward. Always on devices have multiple voltage rails and only the lower power rail may be active when the unit is "off" or in sleep mode. Some Denons do have a physical power switch which turns the power off completely, which is why one member asked whether the power LED was red or green.
If there is no power at all at the supply, an experienced tech could try and diagnose the supply but if the supply has power and the unit is dead then it becomes a more complex issue and likely not repairable. There are dangerous voltages inside these units so it's not recommended for novices to go poking around inside them.
You have now been given advice that you did not want to hear, but it is the correct advice. I know this may be a tough pill to swallow. It is however emblematic of deep seated problems in the AV industry. Yours is unfortunately a classic case, and we welcome you to engage further, especially by telling us of your situation so we can provide pertinent advice.
You can do this right here or personal message one of us. However, it is most useful if kept in the public domain. This helps to keep highlighting the need for change in this sector. There are deep seated problems in the audio and AV sectors now, and needed change is long overdue.
My back up Denon 7.1, 2018 model year, will continue to be sitting on a shelf, in case of needing. All I need is 5.1, Dolby, and HDR. I will be looking for more news on Denon a few months down the road.
I have been known to buy a new Denon every so often, for possible improvements. I think my 2021 model, will last a loooong time. lol But, will still have my 2018 model.
Electrolytic capacitors used in any electronic equipment power supplies have a short shelf life of 2-3 years or so. So, it's not recommended to keep such product on a shelf without periodically powering it in order to protect them from early failure and necessitated costly repair.
As a matter of fact, I had two audio cassette decks which I hadn't used for several years. When I recently powered them, both clearly showed signs of a defective power supply caused by dried electrolytic caps.
