lovinthehd Audioholic Jedi Sep 11, 2012 44,868 0 113 Oakridge, OR Feb 13, 2026 #21 TLS Guy said: Interesting, I have never heard of that in an AVR. Click to expand... You don't follow them much so not a surprise. Yes, some avrs can turn off amps when used as pre-amp.....not a lot, tho.
AcuDefTechGuy Audioholic Jedi Jul 10, 2007 34,057 0 113 Feb 14, 2026 #22 TLS Guy said: Interesting, I have never heard of that in an AVR. Click to expand... That Denon AVR have the Preamp mode which turns off the Amp section? Where have you been? Denon has implemented that feature for like 5 years now.
Alex2507 Audioholic Slumlord Dec 29, 2006 18,125 0 113 Nunya Bidness Feb 14, 2026 #23 Under Manual Set Up it is covered on page 253 of the manual.
Verdinut Audioholic Spartan Aug 31, 2016 5,997 0 113 86 Montreal, Canada Feb 14, 2026 #24 lovinthehd said: You don't follow them much so not a surprise. Yes, some avrs can turn off amps when used as pre-amp.....not a lot, tho. Click to expand... With my AVR-3700, the amps are not actually turned off but only their inputs are disconnected. It's too bad that this AVR is not more energy efficient. Last edited: Feb 14, 2026 Reactions: m. zillch
m. zillch Full Audioholic Sep 5, 2022 399 0 16 Feb 14, 2026 #25 Verdinut said: With my AVR-3700, the amps are not actually turned off but only their inputs are disconnected. It's too bad that this AVR is not more energy efficient. Click to expand... Thanks for pointing that out. I don't follow that specific topic closely but I would assume how your Denon behaves is the same for all Denons with this feature. If they were to instead design a " full/maximum energy efficiency " version as you quite reasonably suggested there would be a problem in that if a consumer later decided to switch the amp section back on there would need to be a 4 to 5 second muted delay, "warm up", before the sound successfully emerged [just like all of us are used to when we power up an AVR] and some consumers would be thrown by that ~5 second delay and assume something was "wrong", hence run to call their dealer/CSR.
TLS Guy Audioholic Jedi Oct 30, 2007 27,289 0 113 79 Eagan MN Feb 15, 2026 #26 AcuDefTechGuy said: That Denon AVR have the Preamp mode which turns off the Amp section? Where have you been? Denon has implemented that feature for like 5 years now. Click to expand... I don't use AVRs and never will. But I can't find any data that any receiver switches off the power amps, but disconnects inputs to the power amps. This would make sense as receivers have regulated power supplies and switching off the amps would be too great a current change for regulation to cope with most likely. So you would need a power supply for the amps and another for the preamp/processor stage. Last edited: Feb 15, 2026
AcuDefTechGuy Audioholic Jedi Jul 10, 2007 34,057 0 113 Feb 15, 2026 #27 TLS Guy said: I don't use AVRs and never will. Click to expand... You don’t need to own something to know basic information about it. Gene, PENG and others have talked about this Preamp mode so many times on AH. Last edited: Feb 15, 2026
lovinthehd Audioholic Jedi Sep 11, 2012 44,868 0 113 Oakridge, OR Feb 15, 2026 #28 TLS Guy said: I don't use AVRs and never will. But I can't find any data that any receiver switches off the power amps, but disconnects inputs to the power amps. This would make sense as receivers have regulated power supplies and switching off the amps would be too great a current change for regulation to cope with most likely. So you would need a power supply for the amps and another for the preamp/processor stage. Click to expand... Maybe something like this thread will help specify the minutiae https://www.audiosciencereview.com/...tz-avrs-looking-for-some-buying-advice.14900/ Maybe @PENG would care to summarize?
H hunterbud Audiophyte Feb 11, 2026 5 0 1 75 Feb 15, 2026 #29 TLS Guy said: Work back from the speaker outputs and see if you can identify the speaker relay. The problem is, that these units are thrown together, and quality of construction usually leaves a lot to be desired. That is why these units are generally unfixable and are basically a disgrace. Click to expand... I down loaded the maintenance manual it’s too big to send you but is available on Denon AVRX7200W avr.sm.pfdf in tracing the circuit back from the buffer I could not find any relays . Let me send you some I can open for your guidance back to me
TLS Guy Audioholic Jedi Oct 30, 2007 27,289 0 113 79 Eagan MN Feb 16, 2026 #30 hunterbud said: I down loaded the maintenance manual it’s too big to send you but is available on Denon AVRX7200W avr.sm.pfdf in tracing the circuit back from the buffer I could not find any relays . Let me send you some I can open for your guidance back to me Click to expand... In that case that unit must have a solid state relay and not a mechanical one with contacts. So the outlook for getting that unit up and running is remote.
Alex2507 Audioholic Slumlord Dec 29, 2006 18,125 0 113 Nunya Bidness Feb 16, 2026 #31 I went sniffing around for prices on used units and found this: ~$350 - $450Units listed for parts or not working, often with known defects like a broken amplifier board. I guess it happens often enough. I can just see Mark waving that shillelagh screaming, "What have I been telling you, you fools! Now go clean your ears!" I would f^%&ing cry if my amp board fried. I still haven't hear the OP say he went into the manual set up and made sure he hadn't turned his amps off or listed the speakers as 'None" in the Speaker Configuration part. I almost feel like PENG could wave a magic wand from Canada and just fix it if he was so inclined. OP, I'm pullin' for ya! I'd love to hear that you got it to work somehow. Reactions: lovinthehd
TLS Guy Audioholic Jedi Oct 30, 2007 27,289 0 113 79 Eagan MN Feb 16, 2026 #32 hunterbud said: I down loaded the maintenance manual it’s too big to send you but is available on Denon AVRX7200W avr.sm.pfdf in tracing the circuit back from the buffer I could not find any relays . Let me send you some I can open for your guidance back to me Click to expand... This seems to be a prevalent problem with that particular receiever. There is this YouTube video that might be your solution. Reactions: Golfx
Alex2507 Audioholic Slumlord Dec 29, 2006 18,125 0 113 Nunya Bidness Feb 16, 2026 #33 TLS Guy said: This seems to be a prevalent problem with that particular receiever. There is this YouTube video that might be your solution. Click to expand... The sound bar would have its own amps, no? I don't think this is the same problem at all but I've had a headache all day and can't quite think. Jesus, I can't believe I'm going to have to try and figure this out. I'm having a hard time accepting this rec'r has any prevalent problems because I'm so in love with mine.
lovinthehd Audioholic Jedi Sep 11, 2012 44,868 0 113 Oakridge, OR Feb 16, 2026 #34 TLS Guy said: This seems to be a prevalent problem with that particular receiever. There is this YouTube video that might be your solution. Click to expand... That video is pretty useless.
Alex2507 Audioholic Slumlord Dec 29, 2006 18,125 0 113 Nunya Bidness Feb 16, 2026 #35 hunterbud said: I called up Denon and went thru the whole process with the trouble shooting guy, Click to expand... This is the part I'm interested in. Did you go through the Audyssey set up or the manual one? If it's the Audyssey set up getting the input assignments and cables right wouldn't matter if I understand that part. Aside from PENG, adk highlander might happen along and have some insight seeing as how my rec'r use to be his rec'r. I bought it from him and had it sit a couple of years unused before hooking it up. So it's not an inherently flawed unit. This is a faith based hobby. You gotta believe. EDIT: Searching for known issues turns up "failed amplifier channel" but no mention of all of them blinking out. Last edited: Feb 16, 2026
lovinthehd Audioholic Jedi Sep 11, 2012 44,868 0 113 Oakridge, OR Feb 16, 2026 #36 OTOH calling a customer service rep at Denon is just being hopeful, usually reading the manual will give you more than they can.
TLS Guy Audioholic Jedi Oct 30, 2007 27,289 0 113 79 Eagan MN Feb 16, 2026 #37 lovinthehd said: That video is pretty useless. Click to expand... The guy claimed it worked on these Denon receivers as well. I admit I"m sceptical. However I found enough reports to get a feel that the OP is not alone in this with his Denon no sound issue and speakers not recognised. I have a feel there is a problem generic to some Denon receivers.
lovinthehd Audioholic Jedi Sep 11, 2012 44,868 0 113 Oakridge, OR Feb 17, 2026 #38 TLS Guy said: The guy claimed it worked on these Denon receivers as well. I admit I"m sceptical. However I found enough reports to get a feel that the OP is not alone in this with his Denon no sound issue and speakers not recognised. I have a feel there is a problem generic to some Denon receivers. Click to expand... He also changed settings he probably made to begin with and is guessing about the other models possibly being affected. Just isn't much to go on. Nor have I had an issue like that particularly with any of my Denons, nor remember reading any issues along these lines particularly.
