Denon AVR speakers setting
  • Thread starter Thread starter Squishman
I don't rely on my Denon to auto adjust for speaker crossovers. In my environment, I found taking the lowest published frequency response of each speaker, and adjust 10 -20Hz higher, I get my best 5.1 sound. Also, my one sub, I let the Denon do its auto adjust to 120HZ. I let the Denon set the distances, etc.
I have tried the 80HZ for the 5 speakers, but not the same for my ears. For me Audyssey, is somewhat okay, w/o going the SPL route...etc.
The Denon merely defaults to 120 hz for the LPF of LFE, the limit of the normal content, but its not a crossover in any case.
The Denon acts as a high-pass filter, and a crossover section limiting lower frequencies going to a tweeter or a mid-range driver is also a high-pass filter.
Eh? Yes, the Denon uses high pass filters in the crossovers if employed. The low pass filter is that preventing the lowest frequencies from going to the speaker when the crossovers are employed, though. Has nothing to do with my point in any case.
No, it's the high pass filter that prevents the lowest frequencies from reaching a driver, while a low pass filter will be used to limit higher frequencies from reaching a mid-range driver, a woofer or subwoofer.
No, it's the high pass filter that prevents the lowest frequencies from reaching a driver, while a low pass filter will be used to prevent higher frequencies from reaching a mid-range driver, a woofer or subwoofer.
Yes, you're right, was thinking sideways, but the high pass filter is unlikely to affect a mid-range driver. The inclusion of tweeters and midrange drivers in your other post pulled me off course :) The way you phrased the Denon acts as hpf didn't help, especially when the comment was on the LPF of the LFE channel.
