Denon AVR-4520ci has arrived and is installed.
  • Thread starter Thread starter surveyor
I read it at Chapters this morning. Yes the measured outputs look almost exactly the same as those for the 4XXX and 3XXX.
Power Output @ 1% THD 2CH 8 ohms/ 2CH 4 ohms/ 5CH 8 ohms:
$3000 Denon 4810: 187.7/303.5/148.2<O:p</O:p
$2500 Denon 4520: 190.7/287.1/145.3<O:p</O:p
$2200 Pioneer SC07: 182.2/301.6/150.5<O:p</O:p
Pretty good. :D
they seem to favor Pioneer!
Insignificant difference on the power output.
Huge difference on the Audyssey XT32 + dual Sub EQ + DEQ. ;)
  • Like
Reactions: surveyor
$3000 Denon 4810: 187.7/303.5/148.2<o:p</o
$2500 Denon 4520: 190.7/287.1/145.3<o:p</o
$2200 Pioneer SC07: 182.2/301.6/150.5<o:p</o
Pretty good. :D
Thanks, The 4520 is a little lighter. But It can hang!
Except that does not tell the whole story. From the AH review measurements:
Although the SC-07 didn't fare well on the bench when tested with 4-ohm loads, it proved to hold up quite well on real world 4-ohm speaker systems driving musical content instead of continuous test tones and only gave up some of its composure as the volume levels were increased. As a result, I'd cautiously recommend using this receiver with highly efficient 4-ohm speakers. With some component tweaks and upgrades, I believe the ICE module could be a worthy contender against traditional linear amplifiers implemented in similarly priced receivers and could also be advantageous in higher power delivery due to its greater efficiency. However, as implemented in this design, it's not quite there yet.
Pioneer SC-07 Conclusion & Overall Perceptions | Audioholics
So numbers don't tell the whole story.
- Rich
I read the review in S and V today. It faired pretty well. It's not a bad AVR!
I would consider it a top performer. Below is a quick comparison of some of the measurements between the Denon, Marantz AVR and Marantz separates, all from S&V/HTM website.
Denon AVR-4520CI A/V Receiver Test Bench | Sound & Vision
AVR-4520
Analog frequencyresponse in Pure Direct mode:
–0.05 dB at 10 Hz
–0.01 dB at 20 Hz
–0.11 dB at 20 kHz
–3.54 dB at 50 kHz
THD+N from the CDinput to the speaker output was less than 0.005% at 1 kHz when driving 2.83volts into an 8-ohm load. Crosstalk at 1 kHz driving 2.83 volts into an 8-ohmload was –74.77 dB left to right and –74.69 dB right to left. Thesignal-to-noise ratio with an 8-ohm load from 10 Hz to 24 kHz with “A”weighting was –107.59 dBrA.
SR-7008
Analog frequency response in Pure Direct mode:
–0.06 dB at 10 Hz
–0.01 dB at 20 Hz
–0.01 dB at 20 kHz
–3.28 dB at 50 kHz
THD+N from the CD input to the speaker output was less than 0.008 percent at 1 kHz when driving 2.83 volts into an 8-ohm load. Crosstalk at 1 kHz driving 2.83 volts into an 8-ohm load was –62.97 dB left to right and –62.81 dB right to left. The signal-to-noise ratio with an 8-ohm load from 10 Hz to 24 kHz with “A” weighting was –102.21 dBrA.
<o:pAV-8801
Analog frequency response in Direct mode:
–0.19 dB at 10 Hz
–0.05 dB at 20 Hz
–0.01 dB at 20 kHz
–0.04 dB at 50 kHz<o:p
</o
The analog THD+Nwas less than 0.017 percent at 1 kHz with a 100-millivolt input and the volumecontrol set to 83.0. Crosstalk with a 100-mV input was –81.35 dB left to rightand –83.60 dB right to left. The signal-to-noise ratio with “A” weighting was–124.15 dBrA.—MJP
The Denon has poorer cross talk numbers than some of its predecessors but still good considering it packs 11 channels of preamp and 9 channels of power amp in one box.
The Denon amazingly has lower THD+N even though the numbers are from CD input to speaker output whereas the high numbers for the Marantz is just for the preamp.
The Marantz has better SNR but again, its just for the preamp. The Marantz AVR-7008 cross talk numbers are not as good as the AVR-4520. I think the Denon's owners should be confident that their AVR, when use as a prepro, would likely be audibly as good as its Marantz counterpart, separate or AVR.
</o
  • Like
Reactions: surveyor
