I agree: Q Acoustics has some very good press for their Speakers. I would not advise their Sub.
@Cloud Strife
Where are you located? Metric is the tip off! Canada? Europe?
This will greatly affect what Subs are available to you and at what cost.
What is the LxWxH of your room, please? Is it closed off, or open to other areas?
RE: Amps and Atmos
As I advised earlier, you don't likely need an Amp, unless you want the extra speaker channels. In your size room, 5.x.4 will be a much more achievable goal if the 3500 can support .4 Atmos. Many people say they feel 5.x.4 is a better set-up anyway. Regardless, space is an issue, and proper Atmos implementation will require distance between speakers in order to aid in the effect that is being generated.
You've now seen other people say it now, too, as I said earlier: ELECTRONICS will NOT IMPROVE your Sound Quality.
I suspect two issues:
Poor set up/Speaker Positioning
Poor Subwoofer performance
Again, by all accounts the Q Acoustics 3050s are supposed to have pretty good SQ, especially at their price point.
Pursue the FREE UPGRADE of looking at your room first! And spend money on a good Subs. (Preferebly 2, because that will smooth out the Bass Response in your room. If two are not possible now, buy the best single subwoofer you can allow yourself to afford now, then begin saving for a second.)
