C carstereoguy Enthusiast Dec 9, 2012 13 0 1 Ontario Mar 23, 2025 #1 I have a Marantz av8802a and did calibrations, it analyses and saves it but when I go to lesson to it, all levels are at 0. Same thing with a denon x4200. What am I missing. thanks
lovinthehd Audioholic Jedi Sep 11, 2012 44,861 0 113 Oakridge, OR Mar 23, 2025 #2 You mean you're running Audyssey on both units and somehow they both reset themselves? Did you save the setup at the end of the routine?
C carstereoguy Enthusiast Dec 9, 2012 13 0 1 Ontario Mar 23, 2025 #3 yes I did save it. I thought something was wrong with my Marantz but did a friends denon today and same thing happen. it analyses than it saves it but no luck all levels are at 0db
lovinthehd Audioholic Jedi Sep 11, 2012 44,861 0 113 Oakridge, OR Mar 23, 2025 #4 carstereoguy said: yes I did save it. I thought something was wrong with my Marantz but did a friends denon today and same thing happen. it analyses than it saves it but no luck all levels are at 0db Click to expand... Unusual two different units would do a reset like that, sounds like the user is still at root. Maybe explain exactly how you're going about it....
C carstereoguy Enthusiast Dec 9, 2012 13 0 1 Ontario Mar 23, 2025 #5 I will try again this week on my Marantz, I've had many Marantz and denon has to be stupid. thanks for the reply but will post later this week thanks
lovinthehd Audioholic Jedi Sep 11, 2012 44,861 0 113 Oakridge, OR Mar 23, 2025 #6 carstereoguy said: I will try again this week on my Marantz, I've had many Marantz and denon has to be stupid. thanks for the reply but will post later this week thanks Click to expand... That's the way it usually is, something you just aren't doing/remembering.....to be safe you might start with a full reset just for the heck of it before starting the Audyssey routine, even though that should be automatic in running the routine.
P PENG Audioholic Slumlord Oct 23, 2004 19,797 0 113 Ontario Mar 24, 2025 #7 carstereoguy said: I have a Marantz av8802a and did calibrations, it analyses and saves it but when I go to lesson to it, all levels are at 0. Same thing with a denon x4200. What am I missing. thanks Click to expand... What do you mean by "save it"? I don't recall the AV8802A or X4200W has a "save" stip. The last step of the process is as shown in the following: Page 223 in the Owner's manual: Reactions: -Jim-
lovinthehd Audioholic Jedi Sep 11, 2012 44,861 0 113 Oakridge, OR Mar 24, 2025 #9 All I meant by saving is approving the end of the routine where the avr keeps it. Newer ones you have multiple save options via both avr/app. Would still like to go thru the whole process and see what's going on as I just would find that both units failing in the same way a bit odd....
Matt34 Moderator Jul 21, 2005 6,574 0 113 Mar 24, 2025 #10 I haven't calibrated without the app in a while, are you selecting a preset at the end of running the room correction?
lovinthehd Audioholic Jedi Sep 11, 2012 44,861 0 113 Oakridge, OR Mar 24, 2025 #11 Matt34 said: I haven't calibrated without the app in a while, are you selecting a preset at the end of running the room correction? Click to expand... His models are pre-app (at least the Denon 4200). Don't think multiple presets came along until later than the editor app, too.
