Definitive Technology BP9080 & Yamaha receiver Issue
snakeeyes
Ratings
726 1 1
#61
Been super busy lately. Just did some more testing. So when I touch any terminals or LFE output the left speaker cuts off. Obviously a bad connection. Just opened it up and saw that one of the soldered points at the eboard has developed a crack. Every time I move a cable (plugging/unplugging) the solder lifts off the board just a hair. See photo. I am mot sure if that can be soldered back up.
I would be looking at new receivers. For connecting to those posts, always use banana plug connectors in the receiver side. It makes it easy to plug and unplug later if you move things around.
diyankov
One more photo - you can see a crack in the green plastic.
diyankov
I bad banana plugs and monster cables that were so heavy and thick that they basically damaged the receiver inside from constant pressure on the terminals
snakeeyes
Ratings
726 1 1
#64
I’ve never seen that happen. Usually 14 gauge with locking banana plugs is not heavy. I have 2060 , 770, and 681. And a few other Ysmahas the past 20 years
diyankov
Mine are much heavier cables due to the thick double layered insulation. To make things worse, the core of the cable has a solid copper wire wrapped around with thinner wires. See photo of cables.
Russdawg1
Ratings
47
#66
While those are thick and probably quite heavy, as long as the caps are screwed in I don’t see any reason for it to crack the board or damage any part of the receiver. The only way I see that happening is if the receiver was pushed up against the wall and forced the cable to push up against the terminals at an odd angle.
diyankov
Agreed. It has never been pushed against a wall but the caps may have been unscrewed at some point
Ratings
4,514 18 37
#68
Good troubleshooting in any case. Monster has been known to kill rca connectors with it's too tight grip at one point, and heavy hdmi cables can take their toll....
diyankov
I hope this is what was causing my problems. The last thing I want is having defective speakers and a shot receiver. I will test everything with another unit soon while I am looking to buy a replacement Yamaha or Denon. Meanwhile I will try to fix this unit just for kicks.
