Thanks for the clarifications. There are a lot of variations on transmission lines. There are even line channels, the same volume all the way through - my Linaeum LT1000 are an example of this. There are tapered channels - some get larger toward the vent opening, and others that get smaller.
And another variation is where the woofer(s) are located within the line channel - having the driver at the closed end, is the "simplest" and therefore I like to think of that as a transmission line. The MK442T has the drivers at *about* 2/5ths from the closed end, and that "dead end" portion is going to resonate (whether or not it is straight or tapered), and therefore it is adding an additional element to the idea of a transmission line.
The ideal transmission line (in my opinion) does several things:
* Prevents the reflection of the backwave from the cone - from "bouncing" off the back of the cabinet, and then coming back out through the cone
* Has minimal cabinet pressurization, which minimized structural resonances
* Prevents bass cancellation - this is the main job of any cabinet - it gets more bass from a smaller woofer
* Extends the bass by mass loading the woofer at the lower end of its response with the air / damping within the transmission line
I agree that widening the line channel toward the opening is closer to a folded bass horn. I think tapering it smaller toward the opening is the better way to go. At the top of its range, the woofer acts similar to an open baffle, and as the frequency drops, it transitions gradually to having more and more mass loading. So the bass response is more even, with no drastic change like a ported design can have.
Transmission line designs are the best of all worlds: clarity and speed of open baffle, but better bass from smaller drivers, like sealed and ported designs.
