a) Jman's room - - imo is small to medium and unless open to other spaces should relatively easy to pressurize by single 12" ported sub
On one wall there's a 3' wide opening to the hallway. On the opposite wall, but not directly opposed to the 3' opening, is a 4' opening to the dining room. The room has standard accoutrements otherwise; carpet, couch, end tables, etc. In most respects it would probably be considered a fairly typical room.
b) The price $769 is not exactly conversion from it's euro price -549,00 € which is according to XE is $663.87
The retail price for the sub in the US is $750, so your conversion is pretty darn close.
c) They claim THX Ultra certification, but in reality this sub performance seem to be significantly below ID competition priced in similar price points aka SVS/HSU
The THX certification is legit - I verified it before doing the review. You bring up an interesting point...
THX certified equipment generally comes at a premium, so it's really not targeted to the "bang for the buck" individuals. There are numerous things that must be adhered to in order to get the certification bestowed upon your subwoofer. From what I can tell a very small percentage of subwoofers have achieved THX Certification. Whether that's due to the fact it's considered irrelevant, or it's simply too difficult to comply with all the regulations, is certainly a matter of debate. To me it's seems more laudable then useless, but that's just my 2 cents.
Without question though, Crystal Acoustics does not make a cheap (or inexpensive) subwoofer; the TX-SUB12 is anything but low end, in parts, materials, construction quality or any other tangible way. Whether or not it's worth the price depends upon your individual needs of course, but for those who want more then a generic looking black box sub I think the TX-SUB12 should be one they consider.
