Thank you, with those speakers, I would set them to 100 Hz. If you don't like how they sound, then try 90, and 80 Hz but not lower because those speakers not not designed to take a lot of power, yet the impedance and sensitivity are on the low side, to average at best. The Sony should be a decent match for those speakers though, it was tested to do 178 WX2 into 4 ohms, and 77 WX7 into 6 ohms by Audiovision.de, presumable at 1% distortions (since they didn't state the THD, I felt safer to assume 1%..)
The specified 44 to 35,000 Hz does not mean a lot without the curve to show the dips and the roll off point. My guess is that it won't have much output below 60 Hz and would likely roll off quickly below 80-90 Hz based on driver size, cabinet dimensions and the bass reflex design as well as the measurements of it's more expensive and bigger tower brother the Unifi slim FSU5. Still this is just my guess, experts like @TLSGuy may be able to take a much more educated guess of the Elac b6.2's F3 and F6 points.
Also, unless your room is really small, those speakers can do better if you set them to "small" and it should work well with the PB1000, again with crossover set to 80 Hz or higher.
