pdf attached...
One of the Q measurements is off... I was still learning how to get good consistent measurements with the added mass method when I was doing this. I'll likely redo the measurements before I do a build, but with the cost of materials still being stupid I'm not in too much of a rush.
I think Nick knows these drivers don't measure to spec, but he told me to build to published spec anyway. TLS and I had discussed, as well as my sharing with a cat from JBL Research... Not much else to say about these Drivers.
Nick does recommend smaller sealed enclosures, usually, with lots of power and DSP to run a Linkwitz Transform for flattening the curve below natural rolloff. For infrasonic output, he advised a 4cu.ft enclosure, FWIW.
I did a HornResp model that showed adequate performance being pushed pretty hard. Of course, it is also well known that Nick's Drivers don't necessarily like being pushed to Xmax. So even though these Drivers can handle gobs of power, and many will put these into larger boxes than the recommended model on Nicks site, there is ample reason to question finished performance.
I've yet to see any kind of quasi-anechoic measurements for a build using these: actual performance results are really unknown. I fantasize about doing some ground plane measurements when I do build just to see what is actually happening with them.
But that is looking like a distant project.
