Can I do better than the Onkyo A-9050 for $500?
zieglj01
zieglj01
Okay the more I delve into this, the more I just want to blow up and start over but bear with me.
No need to blow up, not the end of the world - if you like what you like, then that is cool.
However, once you hear a speaker with better resolution and good off-axis response, and
along with good imaging and sound-stage presentation > then it can/will be an ear opener.
Your call
audioplum
Well last night was kind of an eye opener. I swapped out the Model Sixes for the MC300s. I also swapped in the AVR-1907, leveled out the channels, in Direct mode. Turns out I didn't need a TV to do everything I needed to the AVR, but using the remote sure helped. You can only get things about 75% of the way by using the front panel alone. So that was a success in itself. Right now my iMac is connected via analog; it will be optical tomorrow, but I suspect that won't change things too too much.
As it is, these changes were substantial. We agree that the subwoofer is needed no matter which of my speakers I work with; the MC300s are a far better match to my sub than the Model Sixes. You could just tell they were happier together. It was kind of like lifting a light fog off the sound, going from Model Six to MC300. I've clearly turned in a good direction. I was sitting there last night really thinking about the advice given here regarding buying some different speakers. I can't help but wonder what kind of eye opener that would be. Right now, the amplification side of things has me reasonably satisfied; I am generally more of a lower volume listener, so I was yearning for a "loudness" button that I don't have to fill things out without cranking it, but I suspect someone here will tell me with a superior speaker, I'll not require such a feature.
Steve81
Steve81
Audioholics Five-0
Good stuff! Needless to say, there are a lot of brands out there to look at; the best advice is simply to listen to as many speakers as you can. If you don't have much local to you, there are also a number of internet direct vendors out there. A couple options that immediately jump to mind in that respect are Aperion and SVS, both of which offer a full refund and free return shipping for a risk free home trial.
Unfortunately that's a matter of human hearing as opposed to loudspeaker quality.
Equal-loudness contour - Wikipedia, the free encyclopedia
I didn't see any mention of it taking a quick glance at the manual of your AVR-1907, though in most cases, it's not much more than a preset bass and treble boost. Newer AVRs still have the feature, though it's a bit more sophisticated these days. The Denon I linked earlier has a feature called Audyssey Dynamic EQ which performs that function for example:
Dynamic EQ | Audyssey
Okay, time for experiment #2. Change your surround mode from Direct to Stereo. Run Audyssey. Then on your Parameter setting, use Audyssey Flat or Audyssey Bypass L/R. And then turn on Dynamic EQ (DEQ). Turn off Dynamic Volume.
You can always change everything back if you don't like the results of experiment #2. :D
Steve81
Steve81
Audioholics Five-0
audioplum
Really excited to look at speakers now (!)
Already shortlisting some options, the Wharfedale Diamond 10.1, SVS Ultra Bookshelf.
audioplum
Or maybe just the Diamonds now that I look more carefully at price.
Steve81
Steve81
Audioholics Five-0
Being a KEF guy, I'd toss out the Q100 as being something worth a glance. They retail for $550, but you can typically find them for less.
BoredSysAdmin
BoredSysAdmin
I have a soft spot for Wharfedale - it's been a while since I heard them, but I still remember I loved their sound
Not sure on OP's location, but I would also highly recommend looking at Ascend Acoustics - CMT-340 SE in particular
zieglj01
zieglj01
Good front speakers with a nice bass response - can help keep one from a loudness switch
With your budget and aiming at Wharfedale - look at the 10.2
WHARFEDALE DIAMOND 10.2 BOOKSHELF SPEAKERS (PR) at Music Direct
Also, Monitor Audio Bronz BX-2
Monitor Audio - Bronze BX-2 - 2-Way Bookshelf Speakers-Audio Advisor
audioplum
I'm basically wrangling my brain between 10.1 and 10.2, either way something will be in the mail today.
audioplum
Considering 6 ohm Wharfedales, should I be at all concerned with the "substantial difference in THD" of my 1907 at 6 ohm? Where a 2ch 8ohm is rated 0.08 and a 2ch 6ohm is rated 0.7.
Denon AVR-1907 Specs - CNET
audioplum
Talk with all of you soon. Ended up with a demo pair of 10.2s from MusicDirect. Not sure I could have done any better for the dollar.
audioplum
I'm not even close to being done yet, but another listen tonight with what I have really has me thanking all of you. I'm listening to Joe Satriani's Flying in a Blue Dream, an album I have owned for over 20 years, and I just heard a guitar track in this song I have never heard before. Thrilled.
zieglj01
zieglj01
Well this is how it all begins (turns), you are on your way to becoming an audio-nut. Or as one would say, an audiophile!
Continue to enjoy the adventure.
audioplum
Speakers will be here on Wednesday. The wait is impossible. The more I listen, this Basscube 10S is a box of mud.
