Hello everyone,
I have a Denon AVR 4700h hooked up to a computer through HDMI (on a Geforce 3080), playing audio on a 7.1.2 system. Movies play extremely well and it's a pleasure to listen to concerts. The problem is when playing games and having the GPU under heavy load, there is a very annoying buzzing sounds coming out of the LCR speakers. Muting the speakers makes is easy to play with settings to try to get rid of the buzzing because then only the buzzing is audible, but, nothing works. The best I can do is put all graphic settings and resolution to very low and the buzzing decreases, but never goes away.
I've tried multiple Nvidia drivers, doesn't make a difference.
I've tried changing audio format to every option Windows 11 has, 16bit, 24bit, DTS, Stereo,... doesn't change a thing
Anyone has an idea to solve this?
