Best Center Channel for clearest audio?
fast fred
fast fred
So whats your take on the best Center for clearest audio reproduction under $1000?
Pogre
Pogre
When I had Ultra towers I used an Ultra book for my center and it did very well.
shadyJ
Speaker of the House
Staff member
You might look at the Paradigm Premier 500C or 600C.
MalVeauX
MalVeauX
Hi,
Check out the Chane L6:
PSA MTM-210C:
Sierra Horizon:
RBH SV-661C:
Very best,
Pogre
Pogre
He has an Ultra center channel right now, which is a pretty good center already (I thought?). That's why I suggested a bookshelf.
shadyJ
Staff member
I don't know how the Ultra center performs, but I would expect it to be decent. A significant step up might cost well north of $1k.
ryanosaur
ryanosaur
I would avoid any version of a horizontal MTM or WMTMW design. Any good 3-way horizontal speaker will likely be in a W-T/M-W configuration having the Tweeter and Mid stacked in between the woofers.
Though frankly, the best would be a high quality 2- or 3-way Speaker like Standmount or Tower that matches your mains closely in voicing.
Pogre
Pogre
Like an Ultra bookshelf or another Ultra tower. Tho I'm sure the tower won't work in his setup, but ideally would be the best.
vader540is
vader540is
Chane L6
Or
PSA MTM210C ( I currently own the MTM210C, very happy with it)
stalag2005
I was very impressed with the paradigm 70lcr founders edition for a center channel
Kingnoob
Kingnoob
Infinity r263, emotiva c2+ , and any three ways. Only 2ways id consider have horns usually ,
vader540is
vader540is
Question how great are those PSA MTM's? They are expensive but look like they would be great for Home Theater?
They are amazing for HT. They were built for HT.
The V in SVS is Tom V. He left SVS over 10 years ago to start his own business... Power Sound Audio.
He also has a new line with a M suffix ( China made cabinet)
The new Chane is no slouch either.
Have enjoyed my Infinity RC263 for $150 very much....
K
Kleinst
Thanks, I actually have a RC263 with Infinity R263 x 4. Only interested in highly dynamic speakers that would be dramatically better for TV home theater. Not sure what that is. I could try to replace my front 263s with JBL but that’s likely too lateral a move. Also on my towers I’m limited by A width of around 11 inches max most likely.
Mine is more in contrast to the 520C speaker I replaced with the Infinity. Seems a very competent center aside from going with matching towers from the JBL 5 series....
K
Kleinst
yes it really does work well. For my upstairs I have the rc263 with 590: and it really sounds great together.
shadyJ
Staff member
The PSA MTM speakers are not likely to be a step up in anything except for dynamic range compared to the RC263 speakers which are real over-achievers. If you wanted a center speaker that would be a major upgrade in dynamic range without sacrificing any qualitative attribute, save up for the JTR Noesis 210RM. Or you could really save up and get the Revel PerformaBe C426Be speakers which would be a closer match to your Infinity speakers.
