Yes, I did because I wanted it to be back on spec, not because I need to do it for "better sound quality".   Power not used will not make any difference in sound quality, obviously, because it is not used anyway.
I would say if there is no visible deterioration such as  physical damage, leak, coloration, any sign of overheating etc., there if you don't hear a problem then you don't have a problem.   Of course if money and time is not an issue then do it anyway.
[/QUOTE
thanks and do mind me asking if you use a local shop to do that kind of service or do you recommend always sending in to the manufacturer. For example for my Outlaw 7500 would I only want to send to T
ATI when the time comes.
