And just when did you see me utter a single word about sound quality? A large part of the SQ sits in the ears of the listener and in his preferences, so it is a topic that it is hard to discuss in a meaningful way. And I never said that louder was better either, but loud enough is better then not loud enough all things else being equal.
The Plus/2 will go considerably louder, and deeper, so it is in a different league. The single Plus and the EP500 on the other hand are in the same league, but even those two subs can not be considered twins separated at birth. The Plus is a larger sub with a lower (and variable) tuning point, and it has a longer stroke driver. These 3 factors will give it better performance in the bottom octave, that is not open for discussion
But does that make it a better sub? Well, if you want a bigger sub with better performance in the bottom octave, then definetly yes. If that isn't you main concern then you will have to consider other factors.
I think we are straying to far away from the topic now, and we should probably ask the OP to tell us a bit about what he wants?
After reading Craigs shootout so far, I can tell the the arrival of the HO means that SVS is no longer alone about delivering high SPLs in the bottom octave. As if things were not complicated enough
