Tnx..
Read the link..
However...
Very little info about their test criteria..
Emotiva raised the same point about AC line voltage and current draw. 1 thing I know is that when doing some amplifier projects with D&M, that in their testing lab they actually utlized separate 25 Amp AC lines just for measuring large component amplifiers as they discovered even large AVRs would cause a 4-5 volt drop when doing
full power tests.. Though maybe not so crucial for many or a typical home theater system, published power output specifications are technically part of a product's warranty so the brand has to be sure the unit's real performance specifications. Also if the amplifier is sourced from an outside factory the power output specs are part of the puchasing contract..
Just my $0.02...
