Are you referring to the auto on issue, or the calibration issue? I’ve done calibration at 75% gain on the sub, to see if that sets level 0 or less, still lands at +4. I’d be a bit paranoid going full volume, those test tones are brutal
I didn’t think that raising the sub’s gain helps with auto - on, isn’t it raising the receivers sub level that helps with triggering the subs auto - on?
I’m not to worried about the calibration thing, as can just adjust back to 0 and increase the subs gain, I’m mainly interested if using both sub outs on the receiver would send more signal, as opposed to the typical y splitter method at the sub inputs.
Thanks
