Audio Power Cables / Cords - Do they really make a difference?
bigus
bigus
How are you still here.....?
See my last post. You're not part of the solution. You're part of the problem.
bigus
bigus
See my second last post.
And read it.
I will say this before my permanent ban.
I have a legitimate argument and I will repeat it.
If you believe that cables make a difference. Let's talk about it in a civil way.
If you don't believe cables make a difference. Then go on with your life and don't worry about it.
You can't talk about cables on this forum without being ridiculed.
why have a cable forum?
And read it.
What cable forum? Why wouldn't you be ridiculed about something as silly as cables?
And read it.
Well we do talk about cables. We talk about sensible issues, like appropriate HDCP versions of cables and the best options for longer bandwidth cables. Important issues. However we do not believe in magic and fairy tales. This forum does not originate out of 1600 Pennsylvania Avenue, Washington DC.
bigus
bigus
There you go.
But don't ridicule people for trying different cables....(any type of cable).
Pogre
Pogre
And read it.
They don't and you have no evidence that they do.
Enjoy your cables, lol.
bigus
bigus
I will, thanks.
I've used a Nordost Red Dawn to feed my PS Audio power bar for years.
It's dead quite, but .........
I want to upgrade but would like to see some feedback first on other Nordost power cables.
I will, Thanks.
Well old boy, keep this up and you can run for President of these United States.
Pogre
Pogre
I will, thanks.
This is the most transparent, noise free cable you can find (I even use it myself!) right here. I've compared them to many other brands and can vouch for them myself. Test them out DBT style against your Nordost. I'll bet the farm you'll be blown away when you can't hear the difference.
Give 'em a shot. You can thank me later.
bigus
bigus
No, actually I have.
I have a similar cable in my second system (solid state).
I have 12 guage wire that I bought at Home Depot.
My main system has the Nordost.
How many of those cables have you fed that power bar? Does it get expensive feeding it over the years? How can you afford such an expensive menu to feed that power bar?
Pogre
Pogre
You actually have, what?
Btw, that's not Home Depot 12 Guage wire... that's top of the line OFC! It'll blow your Home Depot wire out of the water. It even makes bad recordings sound better!
My system s dead QUIET. Oh, wait- the power was turned off. OK, it's on again. From my listening position, it's still dead quiet. WooHoo! OEM power cords.
Winning.
Out-Of-Phase
Out-Of-Phase
RED DAWN POWER CORD
It used to be the case that all systems ran on stock power cords, but recent experience has shown that, far from the occasional afterthought they once were, properly designed audiophile power cords are fundamental to system performance. In fact, the effects are so demonstrable, so obvious, that power cords are fast assuming their proper position as the most important cables in your system.
The Red Dawn Power Cord employs high-speed, low-loss, heavy gauge 3 x 14 AWG Micro Mono-Filament conductors sheathed in FEP insulation. The minimal dielectric effect and propagation delay ensures that power is transported as directly as possible, straight to your equipment, while purpose built, audio-grade connectors maintain the low source impedance of your AC supply and ensure superior grounding.
So that's why they are $349.99 for 1 Meter. It's that Micro Mono-Filament.
RED DAWN POWER CORD
No, because it is marketed to audiophiles....just not very knowledgeable ones. :)
NINaudio
NINaudio
So where are these effects that are "so demonstrable, so obvious"?
