I have been reading the debate and comment on Audio Critic's "Audio's 10 biggest lies" with extreme sceptisism and wonder.
It is good to be skeptical. One must carry that baloney detection kit with them at all times.
However friends, NOT all that I read regarding the "10 lies" holds true either! I have been in this hobby of ours for close to 25 years and anyone insisting that all gear sounds the same has simply either NOT heard different gear, is either with some serious hearing problems or just so much into the "measurments show all" mode of thinking that JUST does or can not Listen!
Well, the men behind TAC, including the tech guy, Dr. David Rich, has conducted plenty of comparisons of components over the many decades. However, they do it under levels matched to a close level, 0.1dB spl, and double blind with statistical analysis.
And, measurements do support what one hears. That is backed up by impressive research at place like the Canadian National Research Center.
I can hardly believe the comments that some people put in this and other forums! I have gone through quite a few amps, pre-amps, receivers, CD player and Turntables (not to say tuners and such) in my life to know that NOT a single piece of these sounded the same to my ears.
But, did you level match your comparisons to 0.1B spl? Conducted all of your comparisons under DBT protocol?
I seriously doubt it. And, at times, not even a PhD gives immunity from bias.
And these differences are not simply due to voicing as the Audio Critic or other similar publications seem to be preaching. There are differences between capacitors, resistors and topologies.
You just don't have the evidence on your side to support you that these make an audible difference.
David Rich and Peter Aczel, 'Topological Analysis of Consumer Audio Electronics: Another Approach to Show that Modern Audio Electronics are Acoustically Transparent,' 99 AES Convention, 1995, Print #4053.
There are BIG differences between tubes and transistors and the sound of these is purely based to one's tastes and sensitivities. I have been designing and building speakers as a hobby for close to 20 years and I can tell you that a few simple substitutions to the components used in the crosover (components of the same value but different quality) can make or break am otherwise well designed speaker.
Well now. How do you know that the cap values were so close that it didn't alter anything but its construction did? Speculation only.
There are qualities that can not be measured or explained purely through measurments (yet...) and saying otherwise is just silly.
No, saying what you have is silly without credible evidence, don't you think?
I seriously love reading The Audio Critic but I also read the other publications, with delight (and dismay lots of times) but this is the only way to be well informed on a ceratin subject.
Yes, of course.
YES there is a lot of pseudo science and snake oil in the Hi-End industry and one HAS to use his brain and EARS to see through all the mumbo jumbo that is out there.
Yes, but that brain and ear is subject to bias and easy to fool.
No darn cable is ever worth more than a few dollars but gentlemen there IS a difference between a well designed and executed 12 gauge speaker cable and a 18 gauge electrical patch cord. Any EE worth his name can tell you that and any person with good ears and a decent stero rig can hear the difference.
Well, why do you pick 18ga? Try 16ga vs 12ga or 14ga. Then, you'd have a lot to prove and not much evidence for it. Resistance and inductance is important in speaker cables, period.
http://www.roger-russell.com/wire/wire.htm
Davis, Fred E., 'Effects of cable, Loudspeaker and Amplifier Interactions,' JAES, vol. 39, no. 6 Jun 91
Greenhill, Larry 'Speaker Cables: Can you Hear the Difference?' Stereo Review, Aug 83, pg 46-51.
I know that it can not be resolved in here but my point is: Listen, seriously DO LISTEN and you may at least see part of the truth revealed! ANd although there are some superb values out there I can assure anyone tha wants to LISTEN that no simple chepo receiver can ever compare to a properly built amp. I have gone throught both and I still own both and NO I would could never live with my receiver after having heard what a good (and sensible) gear can do... Have a good one you all!
Yes, one must listen.
That is what TAC has done over the decades and more so than what other pubs try to claim.
But, it is one of the senses that can be fooled so easily that one must take precautions if one wants reliable data. No one is immune.
Perhaps that simple cheapo receiver is not properly built or designed? Or, you are operating outside of its design parameters?
By the way, which amp is properly built?
