panteragstk
panteragstk
The Apple TV has some silly settings and I wish it just had a straight up bitstream mode for all audio. When selecting "best audio", it decodes and sends everything out as PCM. It will pass Atmos Metadata and your DD indicator will light up and Atmos will be displayed on the AVR. You can set it to ignore the metadata and it is sent as PCM. You can also have it bitstream old school DD 5.1 for everything and be done with it. I forgot about the Nvidia Shield cloud games. I may have to look into it. I can get my TF2 on without firing up the ol' XBOX 360. :p
It works just fine. AND you can use your 360 controllers as long as you have the USB adapter.
panteragstk
panteragstk
I have an Apple TV 4K but it’s remote was rejected by the GF as “stupid” so I mostly use Firestick 4K. LOL :)
Firestick is a great device with a bad interface. Too many ads for other shows and services. It won't bitstream HD audio either, which was a big surprise for me.
Kal-El21
Kal-El21
You can also use the remote feature on your iPhone and/or iPad to control Apple TV.
snakeeyes
The new chromecast with Google TV 4K might be one I would like.
Trebdp83
You can use an AVR remote control with the Apple TV 4K by using it’s “Learn Remote” function. I use to have a Denon and it’s remote control was great when controlling an Apple TV.
Trebdp83
To be more clear, the remote control one might like to use with the Apple TV must be able to control multiple devices. A basic receiver remote control can be used but will control the Apple TV while one is using it to adjust AVR functions.
snakeeyes
The chromecast with google TV 4K would have google assistant. Wonder how that compares with Alexa for finding content. We are pretty reliant on Alexa on the firestick 4K to find shows. (Plus it won’t activate Siri on our Apple devices when we talk to Alexa. LOL :). )
How are you defining HD audio? Like Amazon? ;)
afterlife2
afterlife2
I do. Multiple in fact. Atmos works just fine on all my BD rips. No issues at all. Works on streaming services that support it as well. The newer version of the shield supports all the streaming services with Atmos so you can't really go wrong.
Apple TV doesn't support bitstreaming local hi-res audio so it's a no go for me. Any device that doesn't is a no go.
I might pick up the nvidia shield if there is a sale. Been putting it off for too long. How much are they when you got them?
panteragstk
panteragstk
I paid anywhere between $140-160 depending on accessories. Just go with the base model and you're good.
panteragstk
panteragstk
I'm not sure about content finding, but in general it's been much better than Alexa for me. I do know that it's heavily built into the new Chromecast google tv thing, but I don't use voice search so I can't comment.
What kinds of searches do you normally do and I can test it?
snakeeyes
something like this:
Alexa, find storage wars.
afterlife2
afterlife2
Thanks Pant! I guess Black Friday will have a sale like last year. I really want the Pro version.
panteragstk
panteragstk
Works well. Just push the assistant button and say "find storage wars" and there it is. It brought up Hulu for me. Also has the option to add to watchlist and whether or not you've already watched some. You can thumbs up or down too.
afterlife2
afterlife2
Dang i always forgot to use that function on my streamers. I did use it for weather though.
Spinningbull
Spinningbull
I have all the boxes, nvidia shield is the only one that has lossless audio support as well as all the codecs
Sent from my SM-T970 using Tapatalk
panteragstk
panteragstk
I never use it if the remote is required. the NVidia shield TV was supposed to be controllable via google assistant, but functionality is limited. Plus, one of my main apps doesn't have assistant integration, but I'm an old school remote guy anyway.
afterlife2
afterlife2
Once the Nvidia shield goes on sale I’m definitely getting it. I think the old model went on sale last year for 129 i think.
