Do you know what the input sensitivity spec is for the amplifier. Most amps are less than one volt unbalanced input, but it can vary a lot. Determine that and use a multi-meter to set the output voltage from your source device.
1.3v input for the cd inputs.
1v for the normal.
But I am wanting to set the gains on the amp using the clean sweep cd.
For example, my JL 300/2 has a target gain of 24.5V@4ohm for the rated spec of 150W with a 3/4 volume from the source to allow for reasonable overlap with moderate clipping at full power.
My goal is to use the same principle, while targeting a lower wattage(less than the 300WPC the Denon will do @4ohm) to keep my amp below clipping while delivering a little above max rated power for my speakers.
Target of 200WPC@4ohm.
Then, as long as I never crank it full volume, I will never over-power my speakers.
I am fairly sure once I receive my pre-amp, and utilize the "normal inputs", the output will be greater.
Either way, I can set a target gain for each channel utilizing either set-up.
