ahblaza (06-16-2012)
I was looking for a source of some less expensive Speakon's.
Monoprice has a generic version of these only available on already terminated cables.
The 3 footers are $3.62 in 2-9 quantities. This put's the connectors at just $1.56And you get three feet of 12AWG in a really thick and rugged jacket. (hook up wire for internal cabinet wiring).
The Pros: (Outside of price) is the thumb actuated release vs the sleeve release on the Nuetriks and the fact that with the Nuetriks you have to get a jewlers screwdriver involved to expose the screw terminals after assembly. With the Monoprice you just simply take the stress relief collar off. I have fought with the Neutrik on more than one occasion to get the connector back apart.
HT: L-C-R Zaph ZDT3.5's | AVR: Denon 4308Ci | Source: HTPC (Radeon 5k series - AMD Sempron 140 - 4TB server) | Sub:Infinity Reference Dual Opposed | Behringer iNuke 3K-DSP
2.0: Mission Statements | Amp: Crown XLS402D | Source: AMD Brazos CPU | 96GB SSD | 4GB | Win7 x64 | E-Mu 1212m PCIe | Tripplite PR-10 DC Power Supply | Mini-box DC to DC ATX
DS-21 is off the scale
Good info!
And the SpeakOns are just screwed on, which makes the wires easy to cut to length.
Another thing, it's bloody hard to find black-jacketed large-gauge twister-pair speaker wire. So these would be a good source not only for the SpeakOns, but also for the wire. (And even if one tosses the ends... ~60 cents a foot for jacketed 12/2 is only expensive in Monoprice-land.)
I'm curious what you mean by "need a jeweler's screwdriver..." though. I've never had any problem taking apart an ur-SpeakOn, or an SPX model.
Admittedly, my SpeakOn use has been exclusively in controlled temp/humidity homes. And the Neutrik made-in-Liechtenstein models, not the knockoffs that Monoprice has to be using at those prices.
