Audioholics Home Theater Forums
store.audioholics.com EMPTek.com BlueJeansCable.com Emotiva.com VisualApex.com Yamaha.com/yec SpectraCal.com CEDIA moshimonde.com SVS Sound Subwoofers
Go Back   Audioholics Home Theater Forums > Home Theater Hardware Hangout > Write Your Own Review
Reply
LinkBack Thread Tools Rate Thread Display Modes
  #1
Old 01-30-2012, 12:23 AM
ramdasdk is a forum member in good standing
Question S.video to vga connection
i want to give my VC unit output on DVI-I input using VGA to DVI-A analog convertor
VC System out is S.Video so anyone can told me the S.video to VGA pin configuration
does it work if the Pin configuration done?
  #2
Old 01-30-2012, 06:07 AM
BoredSysAdmin's Avatar
BoredSysAdmin should be listened toBoredSysAdmin should be listened toBoredSysAdmin should be listened toBoredSysAdmin should be listened toBoredSysAdmin should be listened toBoredSysAdmin should be listened toBoredSysAdmin should be listened toBoredSysAdmin should be listened toBoredSysAdmin should be listened toBoredSysAdmin should be listened toBoredSysAdmin should be listened to
Default
DFTT
Wrong Thread, Wrong Forum and incomplete question
go to hardforums
__________________
TV: Panasonic TC-P55ST30 Plasma, AVR: Onkyo TX-SR805. The Speaker Company 2x TST2, TC2, 2x TSB , Premier Acoustic PA-120 Sub
Cablevision DVR, XBOX 360, Netgear NeoTV 550 Media Client, Toshiba SA-6980 DVD/SACD, Harmony 880 URC RFS200, PC: SB Audigy2 ZS->JBL LSR2325P <= The best speakers I own
When you're arguing with an idiot, make sure the person you are speaking to isn't doing the same thing.
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Copyright 2011 AUDIOHOLICS, LLC
