Two way Q & A
Hello. I've been following audioholics for a while now and this is where I found out about Funk Audio. I am interested in their 8.1P loudspeaker/monitor, and since manwithnocape is so excited and vocal about these speakers, why are you radically redesigning them? They seem to have excellent qualities. What kind of "redesign" are they getting?
They are very good.
I can state that unequivocally. And they are a pure Nathan production. All I did was some contouring that would smooth out the top end.
So yes there is nothing "wrong" with them.
Grab them while you can.
The next version will be a little smaller, use a different mid-woofer and a different planar. Reasons are simple. I wanted to setup a small speaker that fulfilled the proper mini monitor niche but had the high efficiency that matched the product line we have developed for Funk-Audio.
We need a good entry level two way, and one that is also appropriate for say small room home theater, or hi-end computer speaker, or even recording monitor. The current two way is a little to large to fill that niche. We have settled on a 6 1/2 inch driver that will produce a beautiful speaker coupled with the smaller brother of the planar we use in the MTM. So we will have a truly different offering that will have a different polar response and is much better suited to smaller scale sound reproduction or near field monitoring uses.
Nathan and I have done our homework. We are setting up a very well thought out small lineup of speakers that are not available from many commercial sources if at all.
Wait...
I promise to knock your socks off. I have a three-way coming that needs no sub for all intense purposes, and has efficiency in the Klipsch horn category.
We do things differently. We do things well.
And we make them look dam good!
