jinjuku
jinjuku
Moderator
There will be a jumper on the mother board that will allow you to clear CMOS.
If you can not find the jumper: Remove the coin battery on the Mainboard. Take a metal paper clip and momentarily jump the - and + leads that the battery normally attaches too.
Put the battery back in and try it again.
ParadigmDawg
ParadigmDawg
I feel certain I can fix this since I am now a computer Genius......:D
fuzz092888
fuzz092888
I found a jumper next to the letters "CLR CMOS", but it's still doing the same thing as before.
jinjuku
jinjuku
Moderator
IMO the mainboard is dead. He's not even getting BIOS posts beep error codes.
I have thought this was a hardware problem all along, but there are much more experienced IT guys here.
I will say one thing though it may be the power supply. I have had similar issues with my workstation twice, and thought it was done for. In both cases a new power supply made it come back to life instantly. The second time I put in a power supply that was rated 50% over requirements and have had no issues since.
If it were me I would gamble on a new power supply.
BoredSysAdmin
BoredSysAdmin
+1
That's not bad idea at all. New PSU would cost only $30-40
If you have dell/hp machine - might need to find a special compatible one.
Rickster71
Rickster71
Since he had it apart to install SSD I wonder if something got zapped with a static discharge?
fuzz092888
fuzz092888
Could be. I tried to prevent that by touching metal before I opened everything up and I had the little bracelet with the alligator clip on, but I was working on carpet so it's definitely possible.
