speakerman39
speakerman39
Okay folks, I have reran Audyssey several times today. Have things sounding very good now. More specifically, things are MUCH more balanced. There is no brightness in the 530's now either. Going to listen more and perhaps a little minor tweaking here and there. Just don't feel as though the 530's need any toe-in. BTW, spent merely all day this past Sunday getting everything more precisely placed on both sides. Will post some pics showing the fruits of my labor. But first, here is where things are set right now.
Front Large Changed to "Small" w/a X-over of 60 Hz
Center Small Changed X-over from 40 Hz to 80 hz
Sub 2 speakers LFE 120 Hz
Surr None
FL 8.6' 0 db
FR 8.5' +.5 db
Center 7.7' -3.0 db
Sub 1 13.3' -8.5 db Changed to -4.5 db
Sub 2 10.3' -9.5 db Changed to -5.5 db
I can go in and set Audyssey to By-Pass L/R, Flat, Graphic EQ, OFF, or back to Audyssey. I like it set to Audyssey myself. Anyways, here are some pics that I took on Sunday. Please let me know if it looks better. It sure sounds better. Thanks!
Cheers,
Phil
dave-t
speakerman39
speakerman39
I have used these guidelines for Audyssey and have gotten some great results. I tried to upload the attachment but I kept getting an error. I got if form another forum. Here is the link, it gives some great info about mic placement and tweaking tips before and after calibrating. It is a step by step guide. Chris from Audyssey helped make it I believe.
http://www.avsforum.com/forum/90-receivers-amps-processors/795421-official-audyssey-thread-faq-post-51779-a-191.html#post14456895
Thanks Dave for the link. Will be sure to check it out. Right now things sounds very good. Very happy with the results. Like anything in life, there is always room for improvement!
Cheers,
Phil
