Exactly Thank you. I was actually going to leave it where it was 82Db. Like you said, at master volume "0" The key is to get all speakers to be outputting the same decibel level Thank you!! My big thing was how off YPAO was. I mean think about it for a minute , My RF-7 is 101 db efficient, powered by a Mcintosh Mc252 which is 250 x 2 , now YPAO turns those up to +6 and + 6.5 , that's almost full volume in the receiver , while turning down less efficient speakers like the RC-64ii to +3.5 and RS-62 surrounds to +4.5 . Now one would think maybe the distances are really off, but they're pretty comparable meaning all very similar
Obviously this thread has generated controversy, so I'm going to step in.
Since you are powering the RF-7s with an external amp and a Mac at that, the speaker sensitivity is only one part of the equation now.
A speaker leveling program in the receiver is pretty simple and not likely to be in error. Equalizing a speaker is always problematic as frequency errors are almost always associated with the retained energy. My view and others is that speaker Eq is fools gold. You need to fix the speaker.
As far as level is concerned the overriding issue is the gain structure of the Mac compared to the Yamaha. This is not standard and will be different. So almost certainly the Yamaha is compensating for the difference in gain structure.
The next issue is that the Mac uses auto transformers. This is done by Mac I think mainly to prevent speaker damage from DC off set, as it makes DC offset impossible. Also it reduces current demands somewhat in the output stage.
However other manufacturers have for some time developed reliable high current output stages and reliable robust protection from DC off set.
The downside of auto transformers are many. The first being the it introduces yet another inductor in the speaker path. This path is already a complex witches brew.
Now this is the impedance and phase angle curve of you speakers.
Now you thought those speakers were an easy drive due to high sensitivity, didn't you? Well both the impedance curve and phase angles are horrible. Impedance ranges from 3.2 ohms to 50 ohms. The phase angle varies from -60 degrees to +70 degrees.
So where do you set the auto transformer? Well not on the 8 ohm tap for sure! You set it on the lowest possible, or amp/speaker load will be severely mismatched and current limited.
I have close friend with B & W 800Ds driven by a MAC amp with auto transformers.
One end of the drive, one end of the solitary winding and one end of the load is connected to ground. The positive to the load can be connected to a different region of the winding.
Now my friends 800 Ds are rated at 8 ohms, but drop well below 4 ohms. The dealer set the auto transformers to 8 ohms and the speakers were dogs. Things were much better on the four ohm tap.
I called the MAC engineers and they confirmed that the tap selected should be as close as possible to the minimal impedance of the speaker.
I still think this whole transformer system is a bad idea, especially for most speakers. I have had a chance to look at the situation closely. I know I would never want to own a MAC amp with auto transformers. I do know I would only ever use one with a speaker with a very benign impedance curve and favorable phase angles, and that is not most.
So I'm certain YPAO is setting the speaker levels correctly given the differing gain structures and the almost certain wrong setting of the auto transformer tap you have selected.
