About Aragon Amps
As an owner and avid fan of Aragon amps, I think it is interesting to note that their latest 3005 series amp power ratings are somewhat ambigious just like AV_Phile complains about Yamaha.
3005 is their 5CH 300wpc power amp:
http://www.klipsch.com/product/product.aspx?cid=427
Note they state 300wpc x 3 channels driven = 900 watts total for a 1200 watt power consumption = 75% efficiency, seems reasonable. BTW the 1200 watt power consumption to me implies a 1200VA Xformer which is the same size in the Z9. So basically the Z9 has similar power capabilities (900 watts but must deliver it to 7 main channels and 2 front channels as opposed to 5 channels in the Aragon).
Yet when they rate it in 4 ohms, they say 500 watts, but guess what??, they don't specify # of channels driven! Thus if the max power consumption is 1200 watts and we hold the 75% efficiency, they can only drive one channel at 500watts continuously into 4 ohms.
So I would assume their ability to drive all channels into 8 ohms would be 180wpc and into 4 ohms would be even less. In fact SoundandVison did a 7CH power test on the Z9 and found it to be 140wpc, only 40 watts shy of the Aragon. Meanwhile the Aragon says 300wpc. Why not send the radar police to Aragon?
I own this amp and love it. I don't care that it can't deliver 300wpc to all channels driven. I don't need that much power nor do most home theater systems.
Again here is another example, their 2007 which claims 200wpc in 8 ohms, 300wpc in 4 ohms.
http://www.klipsch.com/product/product.aspx?cid=424
This amp also consumes 1200watts. So it would be logical to conclude a similar sized power supply of the 3005 is used in the 2007 to drive 7 amps instead of 5. Thus this amp should deliver about the same power of the Z9, yet it states 200wpc. Look closer and they rate 200wpc in 3 channels 8 ohms, and 300wpc, 4 ohms (no channel #'s specified!) Call the power police?
I think what we can learn here is there really are no uniform standards for rating multi channel power amps. You have to be aware of how manufacturers are rating them to compare apples to apples.
No way am I discrediting the Aragon amps, just pointing out they also dont deliver or state all channels driven.
