Consider a light bulb.
Does a light bulb shine differently with a different light socket. Even if it does have you ever noticed light bulbs shining differently in different light sockets.
Even if you change light socket brands the bulb still shines the same. So as long as you have an adequate power source a light bulb shines just fine. Sound is a lot like light so just like hooking up a different power source won't change the light bulb changing it for a speaker doesn't change the sound.
Yes, I agree...to an extent..If the power of light is 100w and you are setting output at 100w, a amp that has 98w will light the bulb a bit different when set to 100w coming from a weaker source, vs the bulb that has 140w of power fed. I guess the reserve and comfort of that sound is maybe at play, and perhaps the way things are filtered? Is the comfort of a Rotel amp that makes it sound the way it does? Or is there something else, like filters and such?
Funny enough when I was setting up car audio years back, since the amp being seperate, I knew that it had "no" influence on sound. But the recieivers different components did... but now that the receiver is also involved with the amp, I think there is some difference in sound quality that the DAC, and the other components have. Im not sure how I let my previuos understanding get so tossed...I think it was the stereo sales rep, that played 2 different amps, that sounded way different as I thought they were at the same direct level...hmmm..I have been thrown off a bit...but I have no fallen. thanks for putting it back into perspective. But now I will do one more test, and reconsider a Denon.
So how does one check for a AVReceiver's true output power? as I have some 4ohm speakers to feed.
Also how does one test or judge for other quality circuitry and electronics to expect a clean output from the receiver duty of things?
I remember in cars, Alpine higher end units would have 12v out and other features, then you would add a crossover, and maybe EQ...so which AV receiver has these? Thats when long Precision Power amps were the ticket. Or the older HiFonics that now make very low grade. I also had some Orion gear, and those were powerful under rated. So it looks like a game of the underrated? is it true? is that back in the mix?
So we need to look at the damping factor and such? oofff
Feel free to reply here, but I think I have a new post.
