YSP1 + Oddly-shaped room = ???
Hello,
I've actually been persuing an answer to this question so I might as well share the responses I've gotten so far. Upon seeing the "Audioholics" setup, I was excited to see a real-life application that didn't map directly to the handy little diagrams that Yamaha provided. So I got in touch with Yamaha Canada and a local dealer regarding this. I'll tell you up-front, I wasn't satisfied with either answer (maybe I'm in denial
). My e-mails were identical and the responses are below. I'd really like to hear from the folks at Audioholics about this too
__________________________________
"I am a repeat Yamaha customer and am interested in your new and upcoming single component audio system, the YSP1. (...) if one side of your room is open (no wall in close proximity to reflect sound), will this drastically affect the system's performance or will it accomodate it somehow? I've illustrated what I mean in the ASCII diagram below. The asterisks represent the home theatre area. As you can see, the right side of the theatre has direct surface area to reflect sound as opposed to the left side whose wall is several metres away.
| --OPEN------TV----|
| --OPEN--********|
| --OPEN--********|
| --OPEN--********|
Thank you and I look forward to your response."
Response from Yamaha Canada:
"You can direct the sound beams anyway you want. Yes it will work but not as well as if you had equal wall on each side. Retail price will be $1699.00 (CAD)"
Response from local dealer:
"No, I don't think it would perform well in your desired set up - side
walls are necessary. Have a read through of the owner's manual at the
Yamaha website about the placement - it is very flexible actually but
side walls are needed."
The real debate here I think is if we need an enclosed, 4-walled room, why would we pick this over seperates? Sure, less wires, no drilling or fishing...but I'm sure a lot of you would agree that it's all part of the hobby. The types of consumers that want a YSP-1, IMO, are the ones who have a TV out in an open area where running wires & hiding cables is difficult or very costly. And usually, the room will be oddly shaped with the viewing area not resembling a perfect rectangule or a 45 degree corner.
At any rate, that was a great review and I hope our "Audioholics" can answer my question. (I'm just waiting for the green light
