Yamaha aventage cx a5200 protection mode
Mahmood kasi
Hey every one
When i turn on my yamaha cx a5200 the front red led blinking and wont turn on
Any solution???
How to disable this mode
First thing everyone will say is to do a hard reset to factory setting.
Did you buy the A5200 brand new?
What did you hook up to the A5200?
Are the speaker cables loose anywhere?
Are the jumpers tight on speakers (if there are any)?
The A5200 is rated for up to 8V or more, so preamp voltage is not an issue like some lower-end AVRs that are only rated for under 2V.
Mahmood kasi
Its work agian by hold a1plus info plus main zone button and the unit on
If you want to talk about "rated", let's be consistent, that is, compare apple to apple.
Yamaha's CX-A5100
RCA uUbalanced Preout...............................1.0 V/470 ohm
XLR Balanced Preout....................................2.0 V/470 ohm
Maximum Output level (0.06% THD)
RCA Unbalanced Preout...............................4.0 V or more
XLR Balanced Preout....................................8.0 V or more
XLR Balanced output is 2X that of RCA Unbalanced output, but the gain is half so the overall result will be the same.
Other manufacturer's such as Marantz/Denon, do not provide the "Maximum" output level, they just provide "Rated output", 1.2 V RCA, 2.4 V XLR but you read online review/measurements, they typically did better than Yamaha's, that's for AVRs, and I based it mainly on those measured by Gene, and his comments. Gene has not measured any recent AVP (Marantz), only AVC (Yamaha) so I don't know if his comments on the AVR comparisons would apply to AVC/AVP as well, I would guess not.
Mahmood kasi
I noticed the video quality of Yamaha cx a5200 is very good is it me or its is real
Mahmood kasi
Like onkyo have intelgent volume or intial volume and denon and marantz have source level
Whats in yamaha ??
Bookmark
Bookmark
Actually,
Input Trim -6db to +6db per source
Speaker Trim -10db to +10db per speaker
Independent Main and Zone levels. Initial and Max, plus memory, from -80db to +16.5 in 0.5 increments
Ypao volume, Extra Bass, Adaptive DRC are either off or on.
