While it seems apparant that TWC has major problems with HDCP on their boxes, I don't believe this problem is limited to them. I was unable to use the HDMI output of my SA8300 with my Optoma H79 projector due to HDCP errors. TWC balmes Optoma, Optoma blames TWC and SA, and SA says there are sometimes issues between certain devices.
Now enter the 2600. The Yamaha intermitently reports HDCP errors. Its only digital connection is to the Optoma via HDMI with a HDMI to DVI converter on the other end. The only solution is to turn off the projector and turn it back on. Not exactly a good idea. This also further removes any hope of being able to provide a reliable way to turn the system on for the rest of the family.
I can tell you my friend has to cycle his Phillips plasma due to the same issue.
This has to be the most poorly implemented "feature" ever. It's at least right up there with the XCP problem that is causing Sony to recall CDs over. We buy products with the latest and greatest features only to have to resort to 2-generations old technology to make them work. This was one step forward and two steps back.
I couldn't care less about copying digital content. I just want the darn system to function properly and reliably with the best quality. Is there any way to just disable all the HDCP features of these devices? Or, is there any device I can stick in the middle to make this all go away?
