would this be the proper way to connect my components?
SavidSelim
Hello. i am getting a Grant Fidelity p307 phono stage and preamp along with a Maverick Audio TubeMagic DAC. I was wondering the best way to connect them to my PC, DVD, TT and DVR.
Here is my idea.
There are so many knobs for volume/gain! I would like to use the DAC before the pre so i can use the p307 as a tube buffer stage for my digital sources. Would this work? Should i bypass the volume knob on the DAC??
Thanks!!
WaynePflughaupt
WaynePflughaupt
The connections are correct, except that the amplifier connects to the DAC’s output. I doubt the phono pre amp has enough output signal to drive the amp.
Regards,
Wayne A. Pflughaupt
WaynePflughaupt
WaynePflughaupt
Actually your P-307 is a line preamp, not just a phono pre.
Yes, but did you notice that the P307’s pre amp outs are only .25 volts or .7 volts? Typically that’s a RMS figure. The Alesis amp has an input sensitivity of +4 dBu (1.23 Vrms).
Regards,
Wayne A. Pflughaupt
jinjuku
jinjuku
Moderator
Regards,
Wayne A. Pflughaupt
Wayne,
You have forgotten more than most people know about this stuff.
