Wooden fence in front of speaker
Ruben Crokaert
Hello fellow sound lovers,
I just have a quick question:
We are currently renovating our house and our thinking about redesigning our living room.
I currently love our sound setup, but my wife asked me if there would be a way to hide our sound speakers. She thought about placing the speakers behind a wooden ‘fence’ (hard to describe what it looks like. The picture below gives you an idea of the spacing between the bars/beams)
There would be spaces between the wooden bars, but I don’t think it’s a good idea to mess with it.
My question: Would this fence in front of the speakers effect sound a lot?
I apologise for grammatical mistakes and a lack of ;p
Hope you can help :)
XEagleDriver
XEagleDriver
Ruben,
If the fence is anyway similar to the picture you provided, IMHO it will cause significant audio issues.
- I would expect the fence to interfere with select high frequencies, radically change the audio dispersion pattern, probably create a standing wave pattern of highs and voids in the room (like two pebbles thrown into a still pond).
If aesthetics are a priority, consider transitioning to an in-wall solution for that room. The system may not sound quite as good as your present speakers, but would be better solution than a fence.
- I have an in-wall solution in a similar room and it is pretty darn good (TTP: keeping a stand-alone sub is key!)
Please let us know how you tackle the problem.
Cheers,
XEagleDriver
snakeeyes
They do seem to have a natural resistance to speakers don’t they? Maybe you have another room you can make into a movie room? :)
Acoustically transparent cloth might be an alternative. Can be had in colors to match the decor. Wood fence will give you random combing / peaking issues depending on where you sit relative to them. Not a fan of in-wall, but I agree I'd take that option first. Depending on what your current ones are though, I'd expect to spend a bit more to achieve the same levels of sound that way.
If you can't see it, you won't hear it.
KEW
KEW
You may see what your wife thinks about on-wall speakers!
By reputation, I'd consider KEF or Canton good options.
Note some of these are bookshelf speakers that can be mounted on the wall and others are low profile speakers made to mount exclusively on-wall (like the image below):
https://www.accessories4less.com/make-a-store/category/spkonwall/speakers/on-wall-speakers/1.html?brand_f[]=CANTON&brand_f[]=KEF
In-wall options:
https://www.accessories4less.com/make-a-store/category/spkinwall/speakers/in-wall-speakers/1.html
Almost all speakers would look a lot better, than that butt ugly fence. And yes, that fence would be an earsore as well as an eyesore.
Alex2507
Alex2507
That's a good looking fence. I'm going to put my wife behind one ... in the basement ... beside the box I keep Adam in.
It's the only way to listen to music in peace.
