C clucas6308 Audiophyte Dec 2, 2023 2 0 1 64 Dec 2, 2023 #1 Am I on the correct path, I plan on using USB to a DAC, XLR from DAC to Marantz AV8802A ( but I see the 8802A only has right and left input) is that all I need to go out to the amp for 5.1 or 7.2 etc? Or will it only be stereo? Thanks.
P PENG Audioholic Slumlord Oct 23, 2004 19,797 0 113 Ontario Dec 2, 2023 #2 clucas6308 said: Am I on the correct path, I plan on using USB to a DAC, XLR from DAC to Marantz AV8802A ( but I see the 8802A only has right and left input) is that all I need to go out to the amp for 5.1 or 7.2 etc? Or will it only be stereo? Thanks. Click to expand... If you must use balanced inputs, yes it will be stereo, but you can use the 7.1 unbalanced inputs. There won't be performance degradation using the unbalanced inputs if you keep the interconnects short, say less than 3 meters, and use good quality ones.
TLS Guy Audioholic Jedi Oct 30, 2007 27,305 0 113 79 Eagan MN Dec 2, 2023 #3 clucas6308 said: Am I on the correct path, I plan on using USB to a DAC, XLR from DAC to Marantz AV8802A ( but I see the 8802A only has right and left input) is that all I need to go out to the amp for 5.1 or 7.2 etc? Or will it only be stereo? Thanks. Click to expand... If you are going to use a computer, as a main source, then I recommend you build it round a good gamer board with HDMI out. That is the way to go. You don't need an external DAC then, the receiver or AVP will do the job well. If you have specialized audio needs like mastering and editing, then you can add a DAC for audio only, but that is not needed for reasons of SQ. Reactions: MrBoat, -Jim- and Tankini
C clucas6308 Audiophyte Dec 2, 2023 2 0 1 64 Dec 3, 2023 #4 Got it, I think I will stick with HDMI from computer to the Marantz preamp. Thanks
lovinthehd Audioholic Jedi Sep 11, 2012 44,890 0 113 Oakridge, OR Dec 3, 2023 #5 You have a multich dac like an Okto 8 or something? I'd just stream to the pre-pro myself via dlna/wifi, physical wiring isn't ideal in my situation.
Skye ezer Enthusiast Dec 18, 2023 15 0 1 24 Dec 18, 2023 #6 TLS Guy said: If you are going to use a computer, as a main source, then I recommend you build it round a good gamer board with HDMI out. Click to expand... Is there a difference between HDMI cables of different prices? I mean, if we don't consider the very cheapest ones for $4. There are still cables priced at $60 and $1000+
lovinthehd Audioholic Jedi Sep 11, 2012 44,890 0 113 Oakridge, OR Dec 18, 2023 #7 Skye ezer said: Is there a difference between HDMI cables of different prices? I mean, if we don't consider the very cheapest ones for $4. There are still cables priced at $60 and $1000+ Click to expand... The differences in hdmi cabling is generally about bandwidth and construction. Price is a poor indicator of performance, especially at $1000, that's just throwing your money at charlatans like Fraudioquest.... Reactions: Skye ezer
TLS Guy Audioholic Jedi Oct 30, 2007 27,305 0 113 79 Eagan MN Dec 18, 2023 #8 Skye ezer said: Is there a difference between HDMI cables of different prices? I mean, if we don't consider the very cheapest ones for $4. There are still cables priced at $60 and $1000+ Click to expand... Just buy a 4K rated cable from a reliable vender. In other words HDMI 2.1 rated. Don't spend a fortune. Reactions: Skye ezer
